23 Reo 234 #1 Posted July 18, 2022 Recently picked up a 1994 416 with an Onan P216. The starter was working fine, now it won't spin. I am getting 12.3 volts at the starter from the power cable. The small light blue wire at the starter is dead when I turn the key to start. How should I proceed ? Share this post Link to post Share on other sites
953 nut 64,650 #2 Posted July 18, 2022 7 minutes ago, 23 Reo said: I am getting 12.3 volts at the starter from the power cable. Are you telling us that you have voltage to the starter mounted solenoid input but it is not closing when you turn the key? Be sure the PTO is off and you are holding the clutch down. You probably ought to check out your fuses and the red power wire from the battery to the ignition switch. Any connection that isn't tight or is corroded could be the culprit too. 1 1 Share this post Link to post Share on other sites
23 Reo 234 #3 Posted July 18, 2022 (edited) Yes, the PTO is off and the clutch is completely down. I put new in fuses in but nothing. Everything at the ignition looks good. I slid the ignition wire plug in and out a few times, it is clean. I will clean more connections. Edited July 18, 2022 by 23 Reo 1 Share this post Link to post Share on other sites
WHX?? 55,707 #4 Posted July 19, 2022 Gotta be an electrical gremlin. Check the ignition switch to see if ther is power on the start terminal. If not bad ignition switch. If ther is bad wiring somewhere in between. The solenoid and switch. Bad safety switch or something. Don't forget to check grounds. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,066 #5 Posted July 19, 2022 Idiot lights not indicating a fault? Download this file. The start circuit has it's own diagram. Look for discoloration in the 9-pin connector between the engine and tractor harness. 1 1 Share this post Link to post Share on other sites
lynnmor 8,684 #6 Posted July 19, 2022 8 minutes ago, gwest_ca said: Idiot lights not indicating a fault? Download this file. The start circuit has it's own diagram. Look for discoloration in the 9-pin connector between the engine and tractor harness. By discoloration, he means that the plastic got hot causing it to turn brown. That 9 pin connector can also have a bad connection at several of the pins where the current load isn't enough to cause a lot of heat. 1 Share this post Link to post Share on other sites
23 Reo 234 #7 Posted July 22, 2022 Where are the starting relay, the neutral safety switch and the PTO safety switch? What do they look like and how do you test? I do not have much experience with electrics but I can do the testing and repair if shown . Thank you, Dave Share this post Link to post Share on other sites
