Mark Hackett 9 #1 Posted July 15, 2022 I've got a 1989 Wheelhorse Model 310-8 garden tractor. ID # 2110K806 As per model # it has a 3 forward speed transaxle w/reverse with a high & low range for a total of 8 speed selections While checking fluids & greasing prior to mowing, I noticed that the rear axle seals were leaking. I checked transaxle oil via dipstick and it was clean and still full. Upon further examination I noticed that the axle was tight to hub on one side and had roughly a 1 1/4" gap between hub & housing on the other side. I can't say I've ever took notice or paid attention to the gap before... So I don't know if that axle has always floated in the housing and the seals just need to be replaced due to age and use? Or it something inside the transaxle broke and is now letting it float and took out the seals? I don't have any unusual noises while running and I don't see any metallic in the gear lube... Any advise would be greatly appreciated. 1 Share this post Link to post Share on other sites
oldlineman 1,654 #2 Posted July 15, 2022 (edited) most likely the hub is moving on one or both of the axle's. you need to check and tighten them, but first remove them and replace axle seals. Check to make sure axle bearings are good by checking for up down and front to back play in axles with wheels off the ground. Edited July 15, 2022 by oldlineman 3 Share this post Link to post Share on other sites
Ed Kennell 45,019 #3 Posted July 15, 2022 It is normal for the axles to have up to 1/8" axial in and out movement. As @oldlineman stated above, any radial movement indicates a worn bearing and it should be replaced before installing a new seal. The seals can be replaced easily from the outside, but the case must be split to replace a bearing. 2 1 Share this post Link to post Share on other sites
ri702bill 11,351 #4 Posted July 15, 2022 As stated, if the bearing is bad, the seal is the victim, not the problem. At least with the leak, the hub to axle joint got juiced up - makes foe easier hub removal. One setscrew over the key, or two?? If only one, I add a second one at 90 degrees to lock the hub - drill & tap 3/8-16 UNC and use the 5/16" tap drill to "dimple" the shaft for the second one - gives it a place to bite and not raise a burr to allow for removal in the future... Bill 2 2 Share this post Link to post Share on other sites
Mark Hackett 9 #5 Posted July 16, 2022 I'd like to thank the gentleman that responded to my earlier question. It was indeed, one loose hub... Removed the wheel weights, tires and hubs. Checked the play in the axle (almost a 1/8") as advised - Popped out old seals and replaced them with a pair of 6449 seals and I'm back in business. 3 3 Share this post Link to post Share on other sites
