Steve hathorn 1 #1 Posted July 13, 2022 I have a Onan p216 on a Miller bobcat. It is not charging the battery. Checked voltage at the regulator, not getting any. I guess it is the alternator. Any advise on how to do this would be appreciated. from what I see it has a stator. Where is it located ? How’s difficult is it to replace? thanks, steve Share this post Link to post Share on other sites
Ed Kennell 43,102 #2 Posted July 13, 2022 With the engine running at full throttle, you should measure around 30 volts AC on the two outside lugs. If you do, the stator is OK. Make sure the reg/rec is grounded to the tins. 1 Share this post Link to post Share on other sites
Steve hathorn 1 #3 Posted July 13, 2022 I took the two outside leads off the regulator. With engine running I got no voltage from either lead or both leads. Share this post Link to post Share on other sites
lynnmor 8,087 #4 Posted July 14, 2022 3 hours ago, Steve hathorn said: I took the two outside leads off the regulator. With engine running I got no voltage from either lead or both leads. Here is the Onan Service Manual, see page 8-5 for testing. Be sure you have the voltmeter set on AC volts, not DC and connected to the two leads coming up from the stator. This site will have some photos to help you understand the stator removal. Share this post Link to post Share on other sites
Steve hathorn 1 #5 Posted July 14, 2022 I was testing on dcv. After switching to acv I’m getting voltage in the 40’s. So it must be the voltage regulator. thanks for everyone’s help steve 1 Share this post Link to post Share on other sites
