wallfish 20,174 #176 Posted May 23, 2025 HEY, glad to see you got her going! 29" belt is the correct length for an all original RJ. If the pulley is in the same location it doesn't matter what the engine is I'd advise not doing wheelies on an RJ with that old trans. Same for the Suburbans too. They're not as tough as the newer ones are so busting that trans at this point ain't worth it. 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #177 Posted May 24, 2025 yeah i knew the stock belt size but since it has a bigger motor i wasn't sure if the stock would be slightly to tight or not. good to know about the transmission. i want to use this kinda as a trail/ in the woods tractor so hopefully it'll be okay for that. 1 1 Share this post Link to post Share on other sites
Pullstart 70,513 #178 Posted 4 hours ago Checking in, are you still here? Any progress on the RJ? Share this post Link to post Share on other sites
