Horse Newbie 7,405 #151 Posted December 17, 2023 Did you use sandpaper by hand ? Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #152 Posted December 17, 2023 no used a machine 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #153 Posted December 17, 2023 I don’t see how sanding by hand would remove enough material to cause the pulley to wobble on the shaft… Where did you get the pulley ? 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #154 Posted December 17, 2023 2 minutes ago, The Freightliner Guy said: no used a machine May have took too much off… paint could have been done by hand… 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #155 Posted December 17, 2023 pretty sure it was a stens pulley maybe it came bent? not sure id have to see when i go back up. we used a machine to get most of the paint off but it didnt take off all of teh paint 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #156 Posted December 17, 2023 Did it fit snug on the shaft before you painted it ? Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #157 Posted December 17, 2023 i never put it on the tractor till it was painted and with paint it would not go on after sanding the paint mostly off it went right on 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #158 Posted December 17, 2023 Did you have the tractor running with it all hooked up and seen it wobbling ? Share this post Link to post Share on other sites
Horse Newbie 7,405 #159 Posted December 17, 2023 Should post some pics if you could… Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #160 Posted December 17, 2023 no i had the trans on wood and i spun teh tire by hand and i could see it wobble i may see if i can bend it back if it needs it 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #161 Posted December 17, 2023 Is it a bad wobble ? Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #162 Posted December 17, 2023 ill get a video when im up there 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #163 Posted December 17, 2023 Next time you’re up at Grandpa’s spin it and shoot a video… may be normal if it’s not too bad. 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #164 Posted December 17, 2023 You read my mind… I like your tenacity… 1 Share this post Link to post Share on other sites
wallfish 20,618 #165 Posted December 17, 2023 4 minutes ago, The Freightliner Guy said: ill get a video when im up there Is the set screw tight? Pulley slid all the way on the shaft? Is this a cast pulley or a stamped steel pulley? Hammering on a steel pulley will bend'em 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #166 Posted December 17, 2023 i took the screw out yeah and i only hammered it on the main part not the other part of the pulley and it may be casted cant remember and yeah i made sure it was all the way on the shaft 1 Share this post Link to post Share on other sites
D_Mac 9,339 #167 Posted December 17, 2023 Yes I was going to ask if you tightened the set screw after you got the pulley into position. 2 Share this post Link to post Share on other sites
wallfish 20,618 #168 Posted December 17, 2023 The set screw should tighten it to the shaft and the woodruff key should be in place as well. 2 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #169 Posted December 28, 2023 (edited) On 7/11/2022 at 9:36 AM, Pullstart said: oh the life that has lived… hand clutch? i finally have a answer for this. i was at my grand parents xmas eve and my uncle ryan said when reese would push snow sometimes the belt would start slipping when he started to push more and more snow so that bar was a leverage bar and when reese was plowing snow he would push down that bar so that belt couldnt slip when teh snow started to build up and get heavy. i thought that was pretty neat Edited December 28, 2023 by The Freightliner Guy 1 1 1 Share this post Link to post Share on other sites
Pullstart 71,259 #170 Posted December 28, 2023 Love it! Awesome part of the history! 4 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #171 Posted May 2, 2024 reese's 212 has been returned to stock and is ready to be put in. 2 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #172 Posted December 16, 2024 I know it’s been a while. Been really busy with school and I’ve been focusing on three wheelers. But I hope to have Reese going soon. I know I said I was doing a 212 but stock tank wouldn’t clear the shifter so I could only use 1st and reverse and not the other two. And I hate messing with original parts because I like trying to keep it how I was. But long story short I now have a nother 5horse Briggs but 1 year newer and it runs good and I already know it’ll fit and work. I will still do a 212 roundy some day. 4 2 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #173 Posted May 23, 2025 7 1 Share this post Link to post Share on other sites
Pullstart 71,259 #174 Posted May 23, 2025 Such an accomplishment! Great work Kollin! I hope you’re proud! 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #175 Posted May 23, 2025 yeah pretty proud of myself i finally got to drive it. i was smiling big. still doing trial and error with belts. 32 was to big. 31 was better and what i was using in that video but next time i go up i will try out a 29 inch and see how it does. but front wheels are on there pretty good now. next time i go up i will see if it will do a wheelie. 1 2 Share this post Link to post Share on other sites
