The Freightliner Guy 1,337 #76 Posted July 14, 2022 I still don’t think it had brakes or if it does than where 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #77 Posted July 14, 2022 Has not had sorry typos 1 Share this post Link to post Share on other sites
wallfish 17,582 #78 Posted July 14, 2022 4 hours ago, The Freightliner Guy said: Ok I’ll get those as soon as I can but I might end up rounding the bolts hopefully not though A 6 point socket and a an impact should turn'm right out. A ratchet will work too but using a 6 point socket is the best for some old hardware. The brake band should be located on the left side of the trans and connected with the pedal linkage 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #79 Posted July 14, 2022 Is it that fly wheel thing 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #81 Posted July 14, 2022 Ok thanks so much wall fish I appreciate it 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #82 Posted July 14, 2022 Oliver what position is the brake pressed down or not pressed down 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #83 Posted July 14, 2022 Or anyone I’m guessing it’s not pressed down am I correct 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #84 Posted July 14, 2022 I’m kinda a rookie cuz this is my first wheel horse and I don’t know really anything mechanically about it and such 1 Share this post Link to post Share on other sites
wallfish 17,582 #85 Posted July 14, 2022 The foot pedal is pushed. It will release the belt first (clutch) and then engage the brake band to the brake drum. 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #86 Posted July 14, 2022 Ok thanks 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #87 Posted July 17, 2022 That’s how big the drive pulley is but I don’t know what dimension of drive belt I need and I want to make sure I have the right size belt 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #88 Posted July 28, 2022 Hey guys so a while ago I drained the engine oil in the 5hp Briggs and Stratton and I don’t know how much to put back in because it doesn’t have a dip stick 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #89 Posted July 31, 2022 (edited) Never mind I figured it out it takes 2/3 quarts of 30w oil. Any suggestions on how to clean the fuel tank Edited July 31, 2022 by The Freightliner Guy 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #90 Posted July 31, 2022 Also I got the roll pin set @wallfish told me to get 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #91 Posted July 31, 2022 3 Share this post Link to post Share on other sites
D_Mac 9,241 #92 Posted July 31, 2022 What I do when I come across an issue I haven't addressed yet is that I YouTube it. There are alot of helpful videos for just about every problem you are going to come across. I watch a couple videos then go at it. Trial-and-error is the best teacher. Watching a video also helps me to understand the instructions. I learn better by watching it done then someone trying to explain it. 3 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #93 Posted August 29, 2022 Can y’all tell me what to look for with the engine like things to look for for the rip cord? 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #94 Posted November 15, 2022 (edited) Ok it’s been a long while since the last update about Reese the rj so I’ve been thinking of a engine swap . I plan to put a Honda atc70 engine in it but that’d mean I’d have three gears in reverse with the four gears the engine has and I’d have to use reverse as a forwards gear. Is that ok using reverse as a forward gear let me know. Kollin Edited November 15, 2022 by The Freightliner Guy Wrong word 1 Share this post Link to post Share on other sites
D_Mac 9,241 #95 Posted November 17, 2022 Maybe I missed it but what is exactly wrong with the engine that's on it ? Seems to me it would be so much easier to get that briggs running then to try and engineer that engine swap. See if that briggs has compression and spark. If so order a new carb or carb kit , clean the tank and ride it. 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #96 Posted November 17, 2022 (edited) Um one thing is that you can rewind the cord by turning the engine pulley by hand Edited November 17, 2022 by The Freightliner Guy 1 Share this post Link to post Share on other sites
D_Mac 9,241 #97 Posted November 17, 2022 sounds like the spring is broke, not a big deal to replace. 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #98 Posted November 17, 2022 Fuel tank is as bad or almost as bad as your new snow thrower so I’ll have to figure out how to take it off so I can get the carb off to 1 Share this post Link to post Share on other sites
D_Mac 9,241 #99 Posted November 17, 2022 I cleaned my tank and it is being put back on the blower. 2 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,337 #100 Posted November 17, 2022 Hopefully I can get it going for the big show if I can even make it 1 Share this post Link to post Share on other sites
