Dave 520h 1 #1 Posted July 10, 2022 (edited) Looking for an ignition coil with the wire for a 208-4sb. Edited July 10, 2022 by Dave 520h Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,559 #2 Posted July 10, 2022 Two B&S model engines used - Hope your's is one of them 191707-2175-01 https://www.partstree.com/models/191707-2175-01-briggs-stratton-vertical-engine/blower-hsg-rewind-guards-1/ 193707-0314-01 https://www.partstree.com/models/193707-0314-01-briggs-stratton-vertical-engine/blower-hsg-rewind-a-c-grds-0/ I did not compare part numbers. Share this post Link to post Share on other sites
Achto 29,503 #3 Posted July 10, 2022 2 hours ago, Dave 520h said: Looking for an ignition coil with the wire for a 208-4sb. Solid state coil for 7 - 16hp Briggs & Stratton part number 398811. If your engine happens to have points, just cut the wire that goes to the points and install the solid state coil. A link for an after market equivalent. https://www.amazon.com/Gimiton-Ignition-7HP-16HP-Horizontal-Vertical/dp/B08DJYSP1J/ref=sr_1_2_sspa?gclid=Cj0KCQjw8amWBhCYARIsADqZJoU2nViIdj02b_KexDL3HOahElAXspyAz6JBSn3nWG9fERFeg82eg-4aAuZlEALw_wcB&hvadid=390736459325&hvdev=c&hvlocphy=9019452&hvnetw=g&hvqmt=e&hvrand=1884200029633507809&hvtargid=kwd-830455899335&hydadcr=255_9915205&keywords=bs-398811&qid=1657475003&sr=8-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyOFJNVEhWVlJHVkxGJmVuY3J5cHRlZElkPUEwMjIxMjAzM05XMTRORUtLRTdEUiZlbmNyeXB0ZWRBZElkPUEwMTM0ODE1Mzk2R0FHRFFCOTBJTCZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= Share this post Link to post Share on other sites
