stoneman 10 #1 Posted July 9, 2022 (edited) The engine on my C101 gave up and I'll have to use the C81 to cut grass. The PTO safety switch doesn't work so when last it was used with a deck I had a jumper wire put in so that it'd engage. Since then it's vibrated it's way out. Can show me an image of where the wire should go? I'll make a new jumper wire in the meantime with a spade at each end. Thank you Edited July 9, 2022 by stoneman Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,066 #2 Posted July 9, 2022 If you are sitting in the seat the seat switch should close and power the ignition when the pto is applied. 1 Share this post Link to post Share on other sites
stoneman 10 #3 Posted July 9, 2022 I unplugged that seat switch years ago. In the process of putting the new jump wire under the hood. Thanks 1 Share this post Link to post Share on other sites
953 nut 64,649 #4 Posted July 10, 2022 We don't advocate the elimination of any safety device on any Wheel Horse. 1 Share this post Link to post Share on other sites
