DeepH2O 66 #1 Posted July 7, 2022 I’m ordering all new bearings for my 1989 312-8 w/ 8 speed. I’m having a hard time finding if I 100% have the 1533 or the 111199. The Toro Master Parts viewer says 111199. Could someone else help me verify? Thanks!! Share this post Link to post Share on other sites
daveoman1966 3,880 #2 Posted July 7, 2022 The 1533 bearing APPEARS to be superceded by bearing 111199. Share this post Link to post Share on other sites
DeepH2O 66 #3 Posted July 7, 2022 2 minutes ago, daveoman1966 said: The 1533 bearing APPEARS to be superceded by bearing 111199. https://wheelhorsepartsandmore.com/product/1533-bearings-qty-2/ They are available Share this post Link to post Share on other sites
Achto 30,040 #4 Posted July 7, 2022 5 hours ago, DeepH2O said: I’m having a hard time finding if I 100% have the 1533 or the 111199 it looks like you have the 1533's. If you are ordering from Wheel Horse Parts & More, they have complete kits. Kit number 5 or 6 depending on your axle size. https://wheelhorsepartsandmore.com/product-category/manual-transmissions/page/2/ Kit guide. https://wheelhorsepartsandmore.com/wp-content/uploads/2021/01/Manual-Transmission-Usage-Guide12-20.pdf If you are still unsure, then give Lowell a call. He will gladly help you out, his number is at the bottom of his web page. Share this post Link to post Share on other sites
DeepH2O 66 #5 Posted July 7, 2022 3 hours ago, Achto said: it looks like you have the 1533's. If you are ordering from Wheel Horse Parts & More, they have complete kits. Kit number 5 or 6 depending on your axle size. https://wheelhorsepartsandmore.com/product-category/manual-transmissions/page/2/ Kit guide. https://wheelhorsepartsandmore.com/wp-content/uploads/2021/01/Manual-Transmission-Usage-Guide12-20.pdf If you are still unsure, then give Lowell a call. He will gladly help you out, his number is at the bottom of his web page. Yeah, that’s where I bought all my other bearings from. Lowell had told be the 1533, but then I saw the Master Parts viewer site say it’s the 111199. I guess I will just order the 1533’s and send them back if wrong. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,778 #6 Posted July 7, 2022 111199 did not replace the 1533 bearing. Toro changed the bearings used and some are listed here. Click on the fuzzy picture to see 1" axles 1-1/8" axles 1 1 Share this post Link to post Share on other sites
DeepH2O 66 #7 Posted July 8, 2022 12 hours ago, gwest_ca said: 111199 did not replace the 1533 bearing. Toro changed the bearings used and some are listed here. Click on the fuzzy picture to see 1" axles 1-1/8" axles Darn! It doesn’t list the one for my model 1989 312-8 model 21-12K806 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,778 #8 Posted July 8, 2022 The bearing change happened in 1986 so 1989 should have the 111199 bearings. When the change happened the transmission model number did not change but the tractor model number did change. Share this post Link to post Share on other sites
DeepH2O 66 #9 Posted July 8, 2022 7 minutes ago, gwest_ca said: The bearing change happened in 1986 so 1989 should have the 111199 bearings. When the change happened the transmission model number did not change but the tractor model number did change. I measured my axle with a digital caliper and came up with 1””. I wish I could pick up the phone and call Lowell. I’m over seas and rarely get opportunity to use phone. I would like to order now so it’ll be there when I get home. Thanks for y’all’s help!! Share this post Link to post Share on other sites
DeepH2O 66 #10 Posted July 8, 2022 Lowell messaged me and said “I looked it up according to your model number and you do not have 1533’s if you did they would measure half inch wide inch and a half I D 2 1/2 O” Share this post Link to post Share on other sites
DeepH2O 66 #11 Posted July 8, 2022 Also, can anyone explain why Lowell’s 111199 bearings are so much cheaper than everywhere else? His are between $50-$60 cheaper than everywhere else. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,778 #12 Posted July 8, 2022 Most are reselling Toro parts and Toro is quite proud of them. 1 Share this post Link to post Share on other sites
