ANTPER
310-08 Front spindle 37 Inch Deck
ANTPER
Hello Folks
Just made a turn around a boulder on property edge. As I'm turning right my left front tire caught edge of boulder so it bent around way left as other tire way right! I didn't react quickly enough to stop. SOO the weld that holds the spindle to the steering arm link is broken. I'm sure I can get it welded but trying factor the whole replacement vs just having welded up. Any know the part number of replacement so I can hunt around? Its left side and I have the 37inch side discharge deck with 6 inch wheels. Thanks in advance.
Anthony
  • Sad 1
ri702bill
Anthony:
You can download both the parts manual for your model of tractor and the one for your deck for free here in the Manuals section.
Parts manuals have the exploded pictures and the WH part numbers.
A word of caution - even if you reweld the spindle arm in the exact spot it was, unless you have adustable length tierods, you may not like the result if either the arm itself or other parts are bent...
Bill
Edited by ri702bill
gwest_ca
Look for the IPL or TIPL for your model year on these 5 pages - (IPL = illustrated parts list or TIPL Toro illustrated parts list which is not the best)
https://www.wheelhorseforum.com/search/?&q=310-8&type=downloads_file&search_and_or=or&sortby=relevancy
  • Like 3
ANTPER
1 hour ago, ri702bill said:
Anthony:
Bill
Great point on welding back in exact spot. And no there is no adjustment on my steering link
ri702bill
Strap in, enjoy the ride!!
Weld the mess, hope for the best.
  • Excellent 1
ANTPER
Buddy of mine is a great welder. I gave it to him and mentioned the concerns and we shall see how it goes. Thanks for the input guys and I'll keep you posted
Anthony
ANTPER
On 7/6/2022 at 8:03 AM, ri702bill said:
Anthony:
Bill
 Well I rolled the dice and got nicely welded but>>> The spindle shaft that goes into the front suspension arm doesn't sit flush to keep a nice tight grease seal plus the left wheel is going a tad left when other is straight. Guess I'll do some spindle hunting.
ri702bill
For what it's worth - a plus - you are back up and running:happy-bouncymulticolor:
Do check the condition of your OE non-adjustable tierods for excessive play - new adjustable ones allow you to straightenup the toe-out condition AND allow you to center up the steering wheel - within reason... been there, done that.
Bill
gwest_ca
The flat stock that breaks off often also gets twisted. It does not take much to affect the toe-in. An adjustable wrench can be used to fine tune it.
ANTPER
Bill
New Adjustable links?? Now you got me excited. Tell me more please
ANTPER
I'm not following how to use the Adjustable wrench to tweek it
gwest_ca
Use the wrench to twist the flat bar. With the tie rod bolt entering the flat bar from the top it does not take much of a twist to make a big change in the toein.
clueless
You can still buy the OEM spindle: Left: Toro# 113379, Right: Toro# 113380, about $60 each. I know some will say that's to expensive but is it really, unless you break it again it will last as long as the tractor does.
