Heatingman 977 #1 Posted July 3, 2022 Whats the trick to getting the double pulley off the shaft? standard puller worked for the 2 outboard pulleys, but this one must be different in some way, but Im not sure. Perhaps this one has a threaded shaft? Already bent the lower grove on the pulley a bit, which I should be able to straighten out. Want to get to the bearings to either replace them, or repack. Share this post Link to post Share on other sites
Heatingman 977 #2 Posted July 3, 2022 Got it. Standard pulley puller, added some tension, hammer the tension nut on the puller then turn a bit. Rinse and repeat. Trick I use on pump rebuilds at work. Also let the shaft soak in wd for about 20 minutes. now onto the bearings. the pulley was a single piece. 1 Share this post Link to post Share on other sites
peter lena 10,090 #3 Posted July 3, 2022 @Heatingman deck pulleys can be very deceiving and also very weak on the outer edges , I use these flat pry bars on my deck pulley removal , for very easy work , the key is to use solid LVERAGE THAT IS RIGHT THERE . rocker the bar on top of the spindle deck bolt . push both bars right up against the underside center spindle side wall, bar rocker on top of deck bolt , under pulley , push both out evenly , pulley , lifts off easily . done this on my deck rebuilding , no pulley damage . pete 3 Share this post Link to post Share on other sites
Heatingman 977 #4 Posted July 3, 2022 These bearings do not appear to be greasable, and from what I have found, the Toro 103119 part number has been discontinued. I did find a vendor on ebay that either has a bunch of NOS, or reproduction. for about 50 each. Am I wrong to believe that they are not greasable/rebuildable? I put it in the 12 ton press. If it does come apart, would need more press that I have. Share this post Link to post Share on other sites
Heatingman 977 #5 Posted July 3, 2022 Found them also on wheelhorse parts and more for around 30 each. 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #6 Posted July 3, 2022 1 hour ago, peter lena said: @Heatingman deck pulleys can be very deceiving and also very weak on the outer edges , I use these flat pry bars on my deck pulley removal , for very easy work , the key is to use solid LVERAGE THAT IS RIGHT THERE . rocker the bar on top of the spindle deck bolt . push both bars right up against the underside center spindle side wall, bar rocker on top of deck bolt , under pulley , push both out evenly , pulley , lifts off easily . done this on my deck rebuilding , no pulley damage . pete I've used this method quite a few time with no damage to the pulleys and they come off rather easily. I do something a little bit different though, I 'rock' the two bars so that the pulley can imperceptibly 'wiggle'. I don't use WD, but rather PB Blaster, I think it works much better. I think the wiggling gives the penetrant room to seep in further. Then, I wait a little more time. I've got nothing but time... when it starts to come up, I push it back down and SPIN it on the shaft to clear out the 'mung'. Then it's free and slides right off. Use a thin bar such that you can get it further in than the edge of the pulley because, yeah, they do bend rather easily. Share this post Link to post Share on other sites
JoeM 10,317 #7 Posted July 3, 2022 1 hour ago, Heatingman said: Am I wrong to believe that they are not greasable/rebuildable? Non serviceable. on the other hand those bearings are have lasted that way for more than 30 years. Share this post Link to post Share on other sites
peter lena 10,090 #8 Posted July 4, 2022 @Heatingman think if you can get them for $30 each , that would be the deal , while in the tear down stage , recommend that after cleaning the bottom 0f the deck , you leave it upside down and penetrating oil soak it down . to kill off grunge and soak in the lubricant , been doing that for years to stop rust and preserve deck, pete 2 Share this post Link to post Share on other sites
peter lena 10,090 #9 Posted July 4, 2022 @Heatingman been doing this for years , you have to break the moisture / grunge cycle , with sun heat and lubrication . zero rust or rot , pete Share this post Link to post Share on other sites
Heatingman 977 #10 Posted July 4, 2022 Well, I got it all apart, and placed the order for the bearings from wheelhorsepartsandmore.com Around 100 with a replacement throttle knob. Just in time to be called in for an emergency boiler down at an animal fat processing plant. So much for the night of fireworks. Share this post Link to post Share on other sites
