JCM 11,259 #26 Posted July 2, 2022 9 minutes ago, Bradshawn said: I got a Silverado. But that ranger is a good rig I got no hate for Ford! Someone say Silverado ? 1 Share this post Link to post Share on other sites
Bradshawn 49 #27 Posted July 3, 2022 4 minutes ago, JCM said: Someone say Silverado ? That’s a beaut of a truck! 1 1 Share this post Link to post Share on other sites
WheelHorse520H 710 #28 Posted July 3, 2022 (edited) 25 minutes ago, Snoopy11 said: Soon to be 3... so... maybe I'm getting sucked further into the addiction... ya' think? I picked up number 3 a couple months ago, and I think that it won't stop there. Might take a few years to get better storage but... Welcome to Red Square @Bradshawn!! Edited July 3, 2022 by WheelHorse520H 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,346 #30 Posted July 3, 2022 Here are the 36" rear discharge decks that will fit the C-81 1973-1974 model 5-0621 1975 model 5-0622 1976 model 65-36XR01 1977 model 75-36XR01 1977 model 75-36XR02 1978 model 85-36MR01 1979 model 95-36MR00 (Blades up to this point have the 5/8" x 3/4" double-D center hole unless the spindle has been upgraded) --------------------------------------------------------------------------------------------------------------------------------------------------------------------------- (These decks used blades with a 3/4" center hole) 1979 model 95-36MR01 replaced by 1980-1982 model 05-36MR01 - Last year for bearings with 3/4" ID 1983-84 model 05-36MR02 - First year for bearings with 17mm ID unless older spindles were updated. 1985 model 05-36MR03 1986-1990 model 05-36MR04 1991-1993 model 05-36MR05 1993-2006 model 78305 36" side discharge decks that will fit the C-81 1973-1974 model 5-0721 1975 model 5-0722 1976 model 65-36MS01 1977 model 75-36MS01 1977 model 75-36MS02 1978 model 85-36MS01 1979 model 95-36MS00 - These decks use blades with 5/8" x 3/4" center hole unless the spindle has been upgraded ----------------------------------------------------------------------------------------------------------------------------------------------------------- 1979 model 95-36MS01 replaced by 1980-1982 model 05-36MS01 - Last year for bearings with 3/4" ID 1983-1984 model 05-36MS02 - First year for bearings with 17mm ID unless older spindles were updated. These decks use blades with a 3/4" center hole Best if you can find a deck that uses blades with a 3/4" center hole. Some 5/8" x 3/4" double-D hole blades are no longer produced. Share this post Link to post Share on other sites
Bradshawn 49 #31 Posted July 3, 2022 16 minutes ago, gwest_ca said: Here are the 36" rear discharge decks that will fit the C-81 1973-1974 model 5-0621 1975 model 5-0622 1976 model 65-36XR01 1977 model 75-36XR01 1977 model 75-36XR02 1978 model 85-36MR01 1979 model 95-36MR00 (Blades up to this point have the 5/8" x 3/4" double-D center hole unless the spindle has been upgraded) --------------------------------------------------------------------------------------------------------------------------------------------------------------------------- (These decks used blades with a 3/4" center hole) 1979 model 95-36MR01 replaced by 1980-1982 model 05-36MR01 - Last year for bearings with 3/4" ID 1983-84 model 05-36MR02 - First year for bearings with 17mm ID unless older spindles were updated. 1985 model 05-36MR03 1986-1990 model 05-36MR04 1991-1993 model 05-36MR05 1993-2006 model 78305 36" side discharge decks that will fit the C-81 1973-1974 model 5-0721 1975 model 5-0722 1976 model 65-36MS01 1977 model 75-36MS01 1977 model 75-36MS02 1978 model 85-36MS01 1979 model 95-36MS00 - These decks use blades with 5/8" x 3/4" center hole unless the spindle has been upgraded ----------------------------------------------------------------------------------------------------------------------------------------------------------- 1979 model 95-36MS01 replaced by 1980-1982 model 05-36MS01 - Last year for bearings with 3/4" ID 1983-1984 model 05-36MS02 - First year for bearings with 17mm ID unless older spindles were updated. These decks use blades with a 3/4" center hole Best if you can find a deck that uses blades with a 3/4" center hole. Some 5/8" x 3/4" double-D hole blades are no longer produced. Great information much appreciated! 1 Share this post Link to post Share on other sites
Jeff-C175 7,209 #32 Posted July 3, 2022 Make sure you find a deck with good spindles as replacements are about $150 new. I would suggest that you find a deck with the 17mm bearings as the 3/4" bearings are more difficult to find. Share this post Link to post Share on other sites
Snoopy11 5,731 #33 Posted July 3, 2022 (edited) 1 hour ago, Jeff-C175 said: U N me boaf bruva! All I have room for! WELP... I've only got 2 WHEEL HORSES... Good bit of "other brands" though... so... if you want to count all of those... I've got a real problem... Don Edited July 3, 2022 by Snoopy11 1 Share this post Link to post Share on other sites
Mark Saracino 5 #35 Posted July 7, 2022 Do you know of a used parts store that has a deck for my Toro Model# 73545, serial # 8901329, 1998 520 Lxi, deck (44" cut) deck model # 78357, serial # 8901772. Appreciatively, Mark Saracino Share this post Link to post Share on other sites
ineedanother 2,582 #36 Posted July 7, 2022 25 minutes ago, Mark Saracino said: Do you know of a used parts store... I think you're a member of it Share this post Link to post Share on other sites
