Pop Pop 1 #1 Posted July 1, 2022 I have a 315-8 with warner 5219-9 electric clutch that the outside bearing has died. Does anyone know the replacement number for what looks like a #6006 on the bearing? It measures 2.165 OD X 1.120 ID X .512 thick. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #2 Posted July 1, 2022 The 6006 30 mm Ball Bearing Inner Dimension 30mm X Outer Dimension 55mm X Width 13mm is an open style ball bearing designed for high rotational speeds and high dynamic loads. 30mm = 1.181" 55mm = 2.165" 13mm = .512" Share this post Link to post Share on other sites
peter lena 10,076 #3 Posted July 1, 2022 @Pop Pop noticed that the bearing had wide side rubber grease shields , could be the opportunity ,to do a simple re grease , with a certified hi speed , anti sling , polyurea hi temp grease , or if this causes problems , just replace it as is , pete Share this post Link to post Share on other sites
Pop Pop 1 #4 Posted July 1, 2022 Thanks Gentlemen just wanted to make sure that the ID was OK to use. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #5 Posted July 2, 2022 The ID is different so possibly it is not a 6006 bearing. Do they make a 6006 bearing with an 1-1/8" ID? Part number my be 6006-9 (9/8's) or 6006-18 (18/16's) I can not find one Share this post Link to post Share on other sites
