Pop Pop
315-8 electric clutch
Pop Pop
I have a 315-8 with warner 5219-9 electric clutch that the outside bearing has died. Does anyone know the replacement number for what looks like a #6006 on the bearing? It measures 2.165 OD X 1.120 ID X .512 thick.
gwest_ca
The 6006 30 mm Ball Bearing Inner Dimension 30mm X Outer Dimension 55mm X Width 13mm is an open style ball bearing designed for high rotational speeds and high dynamic loads.
30mm = 1.181"
55mm = 2.165"
13mm = .512"
peter lena
@Pop Pop noticed that the bearing had wide side rubber grease shields , could be the opportunity ,to do a simple re grease , with a certified hi speed , anti sling , polyurea hi temp grease , or if this causes problems , just replace it as is , pete
Pop Pop
Thanks Gentlemen just wanted to make sure that the ID was OK to use.
gwest_ca
The ID is different so possibly it is not a 6006 bearing.
Do they make a 6006 bearing with an 1-1/8" ID?
Part number my be 6006-9  (9/8's) or 6006-18 (18/16's)
I can not find one
