ebinmaine 80,434 #26 Posted July 2, 2022 37 minutes ago, Bill633 said: Consider replacing the wheel hubs with A-Z Tractor hubs. They look great but are pricey. Nearly 3 times the $$ of a good used OE hub. 1 Share this post Link to post Share on other sites
Rob J. 1,944 #27 Posted July 2, 2022 44 minutes ago, ebinmaine said: They look great but are pricey. Nearly 3 times the $$ of a good used OE hub. Already called Lincoln on that, if I have to…… 1 Share this post Link to post Share on other sites
Rob J. 1,944 #28 Posted July 2, 2022 On 6/29/2022 at 11:02 PM, roadapples said: I'd use an angle grinder and a wizard wheel on that hub instead of a torch... You were right, angle grinder was way to go. 1 Share this post Link to post Share on other sites
Rob J. 1,944 #29 Posted July 2, 2022 On 6/30/2022 at 6:38 AM, Pullstart said: I’ve got a whole C series dash/steering assembly… Got any pics of this assembly? I might just go that route if I can’t get this roll pin out which is unlikely. Share this post Link to post Share on other sites
Rob J. 1,944 #30 Posted July 2, 2022 On 6/30/2022 at 3:13 PM, ebinmaine said: Be a good idea to tear into that transmission and check it over from the inside out. Basic hand tools and a little patience. They're super easy. I’m gonna run it first. The axles aren’t leaking at this point and everything feels right. Won’t really know until it’s under power. But I have noted your suggestion, just hope it’s the one thing I don’t have to do to this guy. Share this post Link to post Share on other sites
Pullstart 71,144 #31 Posted July 2, 2022 1 hour ago, Rob J. said: Already called Lincoln on that, if I have to…… What about that hydro roller? It will have the hubs you need and the dash, for less than the price of the special hubs. 3 Share this post Link to post Share on other sites
Rob J. 1,944 #32 Posted July 2, 2022 8 minutes ago, Pullstart said: What about that hydro roller? It will have the hubs you need and the dash, for less than the price of the special hubs. Last ditch option if I have to. I think I have a set lined up.🤞 2 Share this post Link to post Share on other sites
ebinmaine 80,434 #33 Posted July 2, 2022 1 hour ago, Rob J. said: I’m gonna run it first. The axles aren’t leaking at this point and everything feels right. Won’t really know until it’s under power. But I have noted your suggestion, just hope it’s the one thing I don’t have to do to this guy. Have you drained the transmission? There's almost certainly water in the bottom.... Share this post Link to post Share on other sites
Rob J. 1,944 #34 Posted July 2, 2022 5 minutes ago, ebinmaine said: Have you drained the transmission? There's almost certainly water in the bottom.... I’m doing that a little later today, just finished power washing it. Didn’t want to defeat any purpose here. 😉 2 Share this post Link to post Share on other sites
Rob J. 1,944 #35 Posted July 2, 2022 Some more progress, refurbed a seat and fender pan and test fitted it. It’s coming along. As soon as I can get the hubs and roll it the mechanics will come next. I fully expect it to run. How good is another question. 4 Share this post Link to post Share on other sites
Rob J. 1,944 #36 Posted July 3, 2022 Well made good progress this weekend. I power washed it. Looks a lot better. Got the broken hub off and inspected the other. It’s keyway was turned on the shaft 90 degrees. So it came off. Got the dash tire apart and the steering wheel out. I managed to save the shaft with my basic tools. It’s ready for a set of hubs and dash cowl. Then it will be off to mechanics. Rear end looks good feels good so I’m hoping I get lucky there. I’m confident it will run. Thanks everyone for all your help and insight. Pro-tip if you don’t have a press like me just grind the damn thing off. Get close and hit it with heat, popped right off. Cheers! 6 Share this post Link to post Share on other sites
Rob J. 1,944 #37 Posted July 11, 2022 Well a little more progress. It’s officially a roller. So far $270 in this rig. Now off to the mechanics. 5 5 Share this post Link to post Share on other sites
peter lena 10,024 #38 Posted July 11, 2022 @Rob J. when you get in the RIPPIN AND GOUGIN MODE ,STUFF HAPPENS , looks like a perfect opportunity and condition , for a lubrication soak and rub down , that flat / dull paint is begging for , an aerosol lubrication soak down , let it sit a day , rub it down with a clean cloth till dry , no sandpaper , now spray it down again , let sit a day . rub down till dry , Howe's it look ? patina restored ? you could finish it with a linseed oil finish rub down , did you say it was friggin hot ? , kinda melty here too , pete 2 1 Share this post Link to post Share on other sites
Rob J. 1,944 #39 Posted July 11, 2022 1 hour ago, peter lena said: @Rob J. when you get in the RIPPIN AND GOUGIN MODE ,STUFF HAPPENS , looks like a perfect opportunity and condition , for a lubrication soak and rub down , that flat / dull paint is begging for , an aerosol lubrication soak down , let it sit a day , rub it down with a clean cloth till dry , no sandpaper , now spray it down again , let sit a day . rub down till dry , Howe's it look ? patina restored ? you could finish it with a linseed oil finish rub down , did you say it was friggin hot ? , kinda melty here too , pete What’s your favorite “aerosol” lube? 2 Share this post Link to post Share on other sites
wallfish 20,546 #40 Posted July 14, 2022 Whoa, good thing my glasses were on! LoL 5 Share this post Link to post Share on other sites
Marv 996 #41 Posted July 14, 2022 Rob, Looking good. Here is two of my special purpose tractors. C141 wheel barrow and C100 sprayer. Marv 1 Share this post Link to post Share on other sites
ebinmaine 80,434 #42 Posted July 15, 2022 11 hours ago, Marv said: wheel barrow Marv you have any more details on that? Build thread? Explanation of how it works? More pics? Share this post Link to post Share on other sites
Blasterdad 3,167 #43 Posted July 15, 2022 (edited) On 7/11/2022 at 2:44 PM, Rob J. said: She is a real beauty, that battery box looks to be in great shape! I've restored a few of them but only one with the side bracket, the others just have holes in the bottom for rod hold downs. I put large plastic fender washers under them to give a little air gap between the frame & box. Don't be surprised if this one ends up being your favorite! Edited July 15, 2022 by Blasterdad typo 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #44 Posted July 15, 2022 I love the one with the front loader looks good Share this post Link to post Share on other sites
ineedanother 2,833 #45 Posted July 16, 2022 14 hours ago, Blasterdad said: She is a real beauty, that battery box looks to be in great shape! True. First impressions can be deceiving when we look at hoods, seats, tires and other stuff affected by the elements but other stuff like steering linkages, battery boxes, and even the muffler can speak volumes about what might be just as important. 1 2 Share this post Link to post Share on other sites
Rob J. 1,944 #46 Posted July 18, 2022 Hitch update. Did a little cleaning up on the wiring and new spark plug. New fuel lines and filter and bam, runs like a dream. All gears were ran in both hi and low and zero issues. I’m tickled pink! IMG_6038.MOV IMG_6039.MOV 1 5 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #47 Posted July 18, 2022 Nice! It's good to get a couple wins when you take on an unknown project like this. Looks like the worse is behind you! So what's next for it? I'm curious on your build as we both have similar C-100 projects going. 1 Share this post Link to post Share on other sites
Rob J. 1,944 #48 Posted July 18, 2022 22 minutes ago, OutdoorEnvy said: Nice! It's good to get a couple wins when you take on an unknown project like this. Looks like the worse is behind you! So what's next for it? I'm curious on your build as we both have similar C-100 projects going. I’m going straight into putting a real hitch on it. I think I’m going with some wide “mild” AGs on the back and tri-ribs on front. I’d like to get ahold of a set of wheel weights for the 8” fronts and also fill them. 2 Share this post Link to post Share on other sites
ebinmaine 80,434 #49 Posted July 18, 2022 50 minutes ago, Rob J. said: I’m going straight into putting a real hitch on it. I think I’m going with some wide “mild” AGs on the back and tri-ribs on front. I’d like to get ahold of a set of wheel weights for the 8” fronts and also fill them. If you're still "front light" you can add a weight out front too. Share this post Link to post Share on other sites
Rob J. 1,944 #50 Posted July 18, 2022 6 minutes ago, ebinmaine said: If you're still "front light" you can add a weight out front too. Well Eric as you may know I’m not a fan of external weights on my tractors. They’re hard on every component associated with the front end. “Wheel” weights distribute the weight fairly evenly around the spindles as wheel weights and fill do. 2 Share this post Link to post Share on other sites
