"Manic-Mechanic" 1,405 #1 Posted June 27, 2022 I just finished going over the ignition system and this genny wasn't charging. All cleaned up, fresh new bare metal grounds and paint job! Share this post Link to post Share on other sites
ri702bill 10,567 #2 Posted June 27, 2022 Yoy may need to polarize the generator. These 2 documents should help. Delco Remy Regulator Manual 1R-116.pdf delco_remy_regulator_service 1R-111.pdf 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,405 #3 Posted June 27, 2022 5 minutes ago, ri702bill said: Yoy may need to polarize the generator. These 2 documents should help. Delco Remy Regulator Manual 1R-116.pdf 1.76 MB · 0 downloads delco_remy_regulator_service 1R-111.pdf 1.06 MB · 0 downloads Did you view the video? It is working fine. The regulator will polarize on start-up, which it has. Thank you 2 Share this post Link to post Share on other sites
ri702bill 10,567 #4 Posted June 27, 2022 I did not - the darn new puppy chewed the speaker wire! Need to repair / replace it. The documents are older than dirt, but full of info. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,841 #5 Posted June 27, 2022 Way to go. Is the voltmeter working now? 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,405 #6 Posted June 27, 2022 11 minutes ago, gwest_ca said: Way to go. Is the voltmeter working now? Yes! Once it is up to throttle the meter gets super steady and shows above 13v! Happy... 1 2 Share this post Link to post Share on other sites
