Drydock 3 #1 Posted July 6, 2009 Question. Got a good tight 3 speed uni-drive, all run-outs in spec, but its leaking from the output shaft seals. It sat for a long time, I'm thinking the seals dry rotted. Is it possible to replace the seals without splitting the transmission? Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted July 7, 2009 Yes it is. If the hubs come off easily, its a relatively easy job. I use a small screw driver to pick the old seals out, and an old piece of pipe of appropriate size to knock the new ones back in. Clean the axle up before you slide the new seals over it, and be careful you dont cut the new seal on the keyway in the axle Share this post Link to post Share on other sites
HorseFixer 2,015 #3 Posted July 7, 2009 Yep what mike said! :thumbs: Share this post Link to post Share on other sites
MikesRJ 563 #4 Posted July 11, 2009 Anyone have the Napa P/N for the shaft seals? Share this post Link to post Share on other sites
pfrederi 21,040 #5 Posted July 11, 2009 Anyone have the Napa P/N for the shaft seals? 1" CR 9815 1-1/8 CR 11050 Share this post Link to post Share on other sites
Lane Ranger 12,082 #6 Posted July 12, 2009 QUOTE (McGuire2003 @ July 11, 2009 06:53 am) Anyone have the Napa P/N for the shaft seals? 1" CR 9815 1-1/8 CR 11050 I just bought 2 of the NAPA CR 9815's and 4 of the NAPA CR 11050's to reseal a B-80 tranaxle and two 1054 tranaxles. It was $32.00 (which is lot cheaper than your other source choice! Share this post Link to post Share on other sites
MikesRJ 563 #7 Posted July 12, 2009 Two-part harmony, Thanks! Share this post Link to post Share on other sites
