Consigliere 11 #1 Posted June 9, 2022 Does anybody know the parts number for a throttle cable for a 1976 B80? I can't find it on the internet (it's probably here somewhere but I haven't found it). I just to buy a new one. 1 Share this post Link to post Share on other sites
ebinmaine 74,573 #2 Posted June 9, 2022 @Achto has a source 1 Share this post Link to post Share on other sites
Achto 29,857 #3 Posted June 9, 2022 6 hours ago, Consigliere said: Does anybody know the parts number for a throttle cable for a 1976 B80? I believe that it's part #101835 For the cables with a lever control I usually just buy a universal cable assembly and use it to make what I need. Example : https://www.amazon.com/Stens-290-163-Throttle-Control-Cable/dp/B00D9TI6WI/ref=asc_df_B00D9TI6WI/?tag=hyprod-20&linkCode=df0&hvadid=309832912456&hvpos=&hvnetw=g&hvrand=7134125553014333037&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1028057&hvtargid=pla-597752312604&psc=1&tag=&ref=&adgrpid=59800465897&hvpone=&hvptwo=&hvadid=309832912456&hvpos=&hvnetw=g&hvrand=7134125553014333037&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1028057&hvtargid=pla-597752312604 2 Share this post Link to post Share on other sites
peter lena 9,457 #4 Posted June 9, 2022 @Consigliere in addition to @Achto cable source , might think about a lubricant for that, yes even on new stuff . ,https://www.zoro.com/super-lube-4-oz-hydraulic-oil-bottle-150-iso-viscosity-85w-sae-51004/i/G5124506/? also take the time to lay it out so its continually smooth and easy to function , at each clamp mount cable point ,verify its still smooth , also lubricate related , carb linkage points / loose linkage makes for erratic response to cable pull. hang new cable vertically , lubricate top end , so lube oil comes out bottom on slide test , just an idea , local hardware store probably has , super lube bottle . pete 1 Share this post Link to post Share on other sites
Consigliere 11 #5 Posted June 28, 2022 On 6/9/2022 at 6:20 AM, Achto said: I believe that it's part #101835 For the cables with a lever control I usually just buy a universal cable assembly and use it to make what I need. Example : https://www.amazon.com/Stens-290-163-Throttle-Control-Cable/dp/B00D9TI6WI/ref=asc_df_B00D9TI6WI/?tag=hyprod-20&linkCode=df0&hvadid=309832912456&hvpos=&hvnetw=g&hvrand=7134125553014333037&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1028057&hvtargid=pla-597752312604&psc=1&tag=&ref=&adgrpid=59800465897&hvpone=&hvptwo=&hvadid=309832912456&hvpos=&hvnetw=g&hvrand=7134125553014333037&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1028057&hvtargid=pla-597752312604 Hi Achto, I see the throttle listed is the left hand version. Since the throttle for the B-80 is on the right hand side should I order the right hand version? Share this post Link to post Share on other sites
Achto 29,857 #6 Posted June 28, 2022 8 hours ago, Consigliere said: Since the throttle for the B-80 is on the right hand side should I order the right hand version? I usually use just the cable and throw the lever control away. Separate the new cable from the new control lever and attach the new cable to your control old lever. You will also have to cut the new cable to the correct length. If you don't have a control lever then yes, I would look for one in a right hand version. 2 Share this post Link to post Share on other sites
