ranger 1,838 #1 Posted June 6, 2022 This is an additive I’ve used for years. It can be added to any type of oil, grease etc. Four stroke/two stroke engines. I use it in the oil for my lathe,(Myford S7), it really reduced the noise from the change wheels. I use it under the cylinder head bolts on engines which have an initial torque figure, then an angle figure afterwards. It really made it much easier to tighten. It can be added to fuel/coolant systems, (Don’t add it to the screen wash😂), gearbox, etc. Doug. 2 Share this post Link to post Share on other sites
JoeM 9,391 #2 Posted June 6, 2022 Similar to slick 50 I see it uses PTFE? Share this post Link to post Share on other sites
WHX?? 53,754 #3 Posted June 6, 2022 26 minutes ago, JoeM said: PTFE? Teflon? Share this post Link to post Share on other sites
ranger 1,838 #4 Posted June 6, 2022 (edited) 30 minutes ago, JoeM said: Similar to slick 50 I see it uses PTFE? No, label says No P.T.F.E, or other particulates. Doug. Edited June 6, 2022 by ranger 2 Share this post Link to post Share on other sites
JoeM 9,391 #5 Posted June 6, 2022 Yeah I see the no part now....my bad. Wonder what is in it the makes it work? Share this post Link to post Share on other sites
Jeff-C175 7,207 #6 Posted June 6, 2022 1 hour ago, JoeM said: Wonder what is in it the makes it work? Me too... I d/l'd the MSDS, no mention of what is in it other than "EP additives" Nothing on the website... they do tell you what is NOT in it, but not what IS. No PTFE, no ZDDP, etc... They don't distribute in the US for some reason. 1 Share this post Link to post Share on other sites
