Maxwell-8 4,371 #1 Posted June 4, 2022 The guy that bought my WH with a 14hp wants to add a hydraulic pump to it. It will be used to drive a small hydraulic tipper trailer. I have seen some posts were some of you guys added such a pump. Does anyone of you have any pictures on it? as well as some specs? What is better? under the frame, or use the front attach a matic? Maybe be looking into doing the same to one of my horses. 3 1 Share this post Link to post Share on other sites
wallfish 20,553 #2 Posted June 4, 2022 (edited) Here's mine with 2 pumps on it. The FEL uses the right. I kept the hoe completely separate with it's own pump even though it could have been run from just the one. Not sure what's available over there but here's a pump you might be able to compare to. https://www.northerntool.com/shop/tools/product_200329712_200329712 It's the same as the one on the lower left used for the hoe. https://www.northerntool.com/shop/tools/product_200329712_200329712 Edited June 4, 2022 by wallfish 1 3 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #3 Posted June 4, 2022 31 minutes ago, wallfish said: Here's mine with 2 pumps on it. The FEL uses the right. I kept the hoe completely separate with it's own pump even though it could have been run from just the one. Not sure what's available over there but here's a pump you might be able to compare to. https://www.northerntool.com/shop/tools/product_200329712_200329712 It's the same as the one on the lower left used for the hoe. https://www.northerntool.com/shop/tools/product_200329712_200329712 Thanks for that info, helps me and probably him out a lot! Share this post Link to post Share on other sites
Goldnboy 1,149 #4 Posted June 4, 2022 Here is I picture of mine that I added a type two power steering pump and dual hydraulic valve. Hoses run to the back of tractor to auxiliary quick couplers. 3 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #5 Posted June 4, 2022 Very useful information Another thread to follow, and more stuff to order - Flowfit do something similar in the UK, not sure about Belgium though. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,478 #6 Posted June 5, 2022 The pumps driven by belts have bearings that withstand the shaft side loading caused by a belt. Make sure the pump you decide on states it can be belt driven. 3 1 Share this post Link to post Share on other sites
953 nut 68,806 #7 Posted June 5, 2022 Also be sure the rotation is correct for your application. 2 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #8 Posted June 5, 2022 Looking around at pumps (other than ones from car steering) and I notice that "2 stage" is common - any benefit in having/not having? Share this post Link to post Share on other sites
Goldnboy 1,149 #9 Posted June 7, 2022 On 6/5/2022 at 9:37 AM, Dan.gerous said: Looking around at pumps (other than ones from car steering) and I notice that "2 stage" is common - any benefit in having/not having? Are you referring to the type 2 power steering pump mentioned in my prior post? The type 2 pumps have a means to use a external reservoir tank. Many older ones had a built in tank which limits oil capacity and ability to keep oil cool if using it to power multiple cylinders. 1 Share this post Link to post Share on other sites
Dan.gerous 2,696 #10 Posted June 7, 2022 6 hours ago, Goldnboy said: Are you referring to the type 2 power steering pump mentioned in my prior post? The type 2 pumps have a means to use a external reservoir tank. Many older ones had a built in tank which limits oil capacity and ability to keep oil cool if using it to power multiple cylinders. No it was a two stage pressure thing, lower at first - will find a link later and send through. Share this post Link to post Share on other sites
Dan.gerous 2,696 #11 Posted June 7, 2022 https://www.flowfitonline.com/products/8-gpm-hydraulic-two-stage-hi-low-gear-pump-4-bolt-flange-at-3600-rpm Probably not suitable for belt driven, but curious about the two stage bit. Share this post Link to post Share on other sites
