RonnieB2nd 33 #1 Posted June 2, 2022 (edited) I lost spark on my 520H Im trying to figure out if this model has points or not. I need a coil that willl fit wheel horse engine code P220G and possibly magnetic pick-up...Any help would be appreciated/. Its got the original coil on it and I guess its just old and quit..Im gonna test it again to make sure but I need to know if it has points or not..Thank you Edited June 2, 2022 by RonnieB2nd Share this post Link to post Share on other sites
roadapples 6,987 #2 Posted June 2, 2022 Hold the key switch on and wiggle the wires to the fuses... 1 Share this post Link to post Share on other sites
SPINJIM 1,996 #3 Posted June 2, 2022 No points on the 520. Good chance it's a corroded connection somewhere. 1 Share this post Link to post Share on other sites
peter lena 9,797 #4 Posted June 3, 2022 @RonnieB2nd also cracked plug in connections , often showing an electrical cracking dust at the fault area , tight chafing wires , as you hunt , have help using the ignition key , on / of to test reaction with key reaction . just basic stuff . this is only a trial start to your issue , pete Share this post Link to post Share on other sites
lynnmor 8,684 #5 Posted June 3, 2022 Why not just look at the sticky thread right at the top? Here Share this post Link to post Share on other sites
RonnieB2nd 33 #6 Posted June 6, 2022 I got to thinking that I was over thinking. it. Considering it was running fine before the mechanic got it, then suddenly loses fire seemed fishy to me. I removed a spark plug and it had a gap you could stick your finger through (exaggeration) so we closed the gaps and it runs like a top Share this post Link to post Share on other sites
