Retired Wrencher 6,785 #1 Posted May 27, 2022 I had this for a while it was Sparky's before that Docwheelhorse. It is ready. Hope it does not rain. I hope you enjoy the picks. 11 Share this post Link to post Share on other sites
Handy Don 16,942 #2 Posted May 27, 2022 1 hour ago, Retierd Wrencher said: It is ready Might wanna put in the rest of the wheel lugs!? 3 Share this post Link to post Share on other sites
kpinnc 18,744 #3 Posted May 27, 2022 19 minutes ago, Handy Don said: Might wanna put in the rest of the wheel lugs!? 3 per wheel at least! 2 Share this post Link to post Share on other sites
JoeM 10,092 #4 Posted May 28, 2022 what kind of patina preservative are you using? 1 Share this post Link to post Share on other sites
Retired Wrencher 6,785 #5 Posted May 28, 2022 14 hours ago, Handy Don said: Might wanna put in the rest of the wheel lugs!? You are right. Good eye. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,785 #6 Posted May 28, 2022 2 hours ago, JoeM said: what kind of patina preservative are you using? I just use Marvel Mystery oil. Wipe it on let it set wipe off any excess. It last for a while. Quick and easy. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,785 #7 Posted May 28, 2022 I just thew them on for a quick run to see if everything works. 1 Share this post Link to post Share on other sites
adsm08 4,780 #8 Posted May 28, 2022 16 hours ago, Retierd Wrencher said: This will not pass muster in PA. For a motor vehicle to be certified safe for use in Pennsylvania all wheel retaining hardware must be installed, as originally equipped, in the correct type and quantity, or matching another certified configuration (ie, you are allowed to swap a lug bolt setup to studs and nuts). 2 2 Share this post Link to post Share on other sites
