Allen E. 1 #1 Posted May 27, 2022 Does anyone know the mowing deck belt size on a 208-3? I can only find drive belts. This belt is @ 1/2 x 48" but I can't find a # on any diagrams. It powers the belt that actually spins the blades Share this post Link to post Share on other sites
squonk 45,614 #2 Posted May 27, 2022 If it's a regular V style belt Napa 4L480W will work 1 Share this post Link to post Share on other sites
stevasaurus 23,627 #3 Posted May 27, 2022 Might need a little more information. Are you talking about the belt that's from the mule drive to the mower deck. Do you know the model # of the deck or at least the size?? What is a 208-3...guessing a vertical shaft engine?? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #4 Posted May 27, 2022 Is this the deck you have? There is also a 32" side discharge and a 36" rear discharge. Click on the fuzzy picture for more info Share this post Link to post Share on other sites
Allen E. 1 #5 Posted May 27, 2022 Thanks-This diagram is everything I needed! 1 Share this post Link to post Share on other sites
Allen E. 1 #6 Posted May 27, 2022 29 minutes ago, stevasaurus said: Might need a little more information. Are you talking about the belt that's from the mule drive to the mower deck. Do you know the model # of the deck or at least the size?? What is a 208-3...guessing a vertical shaft engine?? 208-3 is the Wheelhorse model number. Thanks for your help. The guy just below sent a diagram Share this post Link to post Share on other sites
