snowhound 106 #1 Posted May 27, 2022 Witn a 3amp charging system what voltage should I have at the battery? Share this post Link to post Share on other sites
ebinmaine 77,824 #2 Posted May 27, 2022 (edited) I'm not specifically familiar with the 3 amp charging system having had only 15s here that I've worked on. I'm going to put in my guess that you still should have somewhere around 13.8 volts with the engine running at full throttle. Edited May 27, 2022 by ebinmaine Corrected voltage Share this post Link to post Share on other sites
squonk 45,810 #3 Posted May 27, 2022 You better be in the mid to high 13's at least with it fully charged and running. 2 Share this post Link to post Share on other sites
ebinmaine 77,824 #4 Posted May 27, 2022 1 minute ago, squonk said: You better be in the mid to high 13's at least with it fully charged and running. What's considered overcharging? 14.5, little higher? 1 Share this post Link to post Share on other sites
squonk 45,810 #5 Posted May 27, 2022 14.5 is about the limit 1 1 Share this post Link to post Share on other sites
squonk 45,810 #6 Posted May 27, 2022 General rule of thumb. Your milage may vary! 1 Share this post Link to post Share on other sites
ebinmaine 77,824 #7 Posted May 27, 2022 9 minutes ago, squonk said: General rule of thumb Excellent chart Mike. Thanks for posting that. I edited my first post. Share this post Link to post Share on other sites
snowhound 106 #8 Posted May 27, 2022 Thanks for all the replies. I'm only getting 12.68 so I guess I need to do some more research on what would be causing the low reading Share this post Link to post Share on other sites
pfrederi 20,062 #9 Posted May 27, 2022 Kohler manual is your friend. At 3000 RPM a voltage of more than 12.5 means system is operating properly. 1 Share this post Link to post Share on other sites
squonk 45,810 #10 Posted May 27, 2022 Considering 12.5 volts is 75% charged, that isn't much of a charging system. 1 Share this post Link to post Share on other sites
