Michael Kline 2 #1 Posted May 25, 2022 Last couple of years I used the 3rd notch on the deck height adj. This year I need to use the 4th notch and it even seems lower . What am I missing Share this post Link to post Share on other sites
8ntruck 8,397 #2 Posted May 25, 2022 You counting notches from the front of the quadrant or the back? Generally, moving the lever towards the back of the deck raises the blades. I'm working from memory here, so I might be mistaken. Share this post Link to post Share on other sites
lynnmor 8,306 #3 Posted May 25, 2022 Check for wear in the mower wheel bearings. Check the air pressure in the tractor tires. Check for wear on all the parts that mount the deck. Be sure that the blades are of the correct design, and that they are properly sharpened. Set the transport height per the owners manual. Level the deck using the owners manual for it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #4 Posted May 25, 2022 Make sure the blades are not installed up-side down. Been there - done that. 1 Share this post Link to post Share on other sites
