Mike C160 251 #26 Posted May 25, 2022 2 minutes ago, Achto said: Yes. A wider gap advances to timing. Right-O. Good to know. What about the ethanol thing? Ever heard of that issue? BTW - I found 2 of those springs and have ordered them. Maybe I dont need em yet, but this fall I will be rebuilding to of these K341s and it wont hurt to install fresh springs. Cheers Share this post Link to post Share on other sites
Achto 32,108 #27 Posted May 25, 2022 1 hour ago, Mike C160 said: What about the ethanol thing? Ever heard of that issue? I usually don't run ethanol in mine but I have not heard of any one changing the timing for it. Share this post Link to post Share on other sites
WHX?? 57,466 #28 Posted May 25, 2022 I gotta try going to 18 on a C-121. Almost think she fires too soon. 1 hour ago, Mike C160 said: it wont hurt to install fresh springs. No when you see how delicate they are. Share this post Link to post Share on other sites
Mike C160 251 #29 Posted May 25, 2022 Well Now, After rounding up all the usual suspects, it turned out the culprit was one we did not suspect. The old starter solenoid had a whopping voltage drop of 3 volts across it during cranking. Without getting my slide rule and calculator out I can already estimate the current or amperage loss would be approaching 75 amps easy. As soon as i measured that drop I knew right away this had to be changed out. Once a new one was installed and all the terminals cleaned, it turns over like the wind now without issue at all. I can see its time to change all the high current cables. So they are on my list. I cannot measure a voltage drop across the new solenoid. 1 3 Share this post Link to post Share on other sites
ebinmaine 79,729 #30 Posted May 25, 2022 2 minutes ago, Mike C160 said: Once a new one was installed and all the terminals cleaned, it turns over like the wind now without issue at all. I can see its time to change all the high current cables. So they are on my list Nice work Sir. I make my own 4 or 6 gauge cables. One could also procure a set from Squonk or a local auto parts store. 1 Share this post Link to post Share on other sites
Handy Don 16,961 #31 Posted May 25, 2022 50 minutes ago, Mike C160 said: whopping voltage drop of 3 volts across it during cranking Yikes. First time I've heard of a solenoid failing this way. Good investigating! 1 Share this post Link to post Share on other sites
953 nut 67,469 #32 Posted May 25, 2022 So glad you found the problem prior to needlessly going into the engine. For future reference the ACR mechanism can be seen with the cam gear cover, The springs don't show in this photo but can be examined with a small inspection mirror. 1 Share this post Link to post Share on other sites
squonk 47,421 #33 Posted May 25, 2022 The paint alone on that solenoid was enough to cause problems. Share this post Link to post Share on other sites
Mike C160 251 #34 Posted May 25, 2022 39 minutes ago, squonk said: The paint alone on that solenoid was enough to cause problems. The back side of those nuts are cleaner than what you see. I didnt see any signs of heating on those posts, but there is some signs of heating on the back of the solenoid. I suspect the contacts inside are corroded. Ive placed it in the circular file for no future reference 2 Share this post Link to post Share on other sites
Mike C160 251 #35 Posted May 25, 2022 44 minutes ago, 953 nut said: So glad you found the problem prior to needlessly going into the engine. For future reference the ACR mechanism can be seen with the cam gear cover, The springs don't show in this photo but can be examined with a small inspection mirror. Pictures are worth a thousand words for sure. Thanks. I think i can see the tab of the spring bent over the weight... Cheers. 1 Share this post Link to post Share on other sites
Handy Don 16,961 #36 Posted May 26, 2022 (edited) 44 minutes ago, Mike C160 said: Ive placed it in the circular file for no future reference I used to keep a box of "someday I'm gonna open this up to see what happened to it" stuff. Finally took my London friend's advice and binned it. Edited May 26, 2022 by Handy Don 2 1 Share this post Link to post Share on other sites
WHX?? 57,466 #37 Posted May 26, 2022 I often forget about solenoids since the bulk of my herd is S/G. Wonder why it started fine hot? 2 Share this post Link to post Share on other sites
WHX?? 57,466 #38 Posted May 26, 2022 12 hours ago, Handy Don said: I used to keep a box of "someday I'm gonna open this up to see what happened to it" stuff. I often do that too....figure with my 11 thumbs and it's already broke I got nothing to lose. 2 2 Share this post Link to post Share on other sites
ebinmaine 79,729 #39 Posted May 26, 2022 11 hours ago, WHX?? said: I often forget about solenoids since the bulk of my herd is S/G. Wonder why it started fine hot? Perhaps... because it's less straining on the electrical system to start a hot engine? 2 Share this post Link to post Share on other sites
Handy Don 16,961 #40 Posted May 26, 2022 1 hour ago, WHX?? said: I often do that too....figure with my 11 thumbs and it's already broke I got nothing to lose. I recall several outcomes: 1. Aha, I see how this worked and yep, this thing was toast 2. Arrrrggggghhhhh. I could have fixed this and not bought a new _____ (fill in the blank) 3. Why did I save this made-to-fail hunk of junk? 2 Share this post Link to post Share on other sites
ebinmaine 79,729 #41 Posted May 26, 2022 14 hours ago, Mike C160 said: Ive placed it in the circular file for no future reference 😂 Interesting verbiage there. Well done. 1 1 Share this post Link to post Share on other sites
Mike C160 251 #42 Posted May 26, 2022 2 hours ago, ebinmaine said: Perhaps... because it's less straining on the electrical system to start a hot engine? Likely. A warm engine turns easier. Battery got a fresh charge....etc But I did not state that after the repair, it turns over much quicker now both cold and hot. So I think a little from column A and a little from Column B. 4 Share this post Link to post Share on other sites
WHX?? 57,466 #43 Posted May 27, 2022 8 hours ago, Mike C160 said: Likely. A warm engine turns easier. Battery got a fresh charge....etc But I did not state that after the repair, it turns over much quicker now both cold and hot. So I think a little from column A and a little from Column B. Agreed Mike Share this post Link to post Share on other sites
