ebinmaine 75,721 #1 Posted May 9, 2022 I have a KT17 here from which I've removed and rebuilt the starter. 1 new bushing and a good cleaning. Rotational movement seems good but how much should the main shaft move end to end? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,841 #2 Posted May 9, 2022 Is this a solenoid shifted starter or a Bendix starter? 1 Share this post Link to post Share on other sites
ebinmaine 75,721 #3 Posted May 9, 2022 17 minutes ago, gwest_ca said: Is this a solenoid shifted starter or a Bendix starter? By solenoid shifted I assume you mean the solenoid would be bolted or attached directly to the starter? It is not that. The solenoid is mounted to the steering tower on mine. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,841 #4 Posted May 9, 2022 OK. Only see a spec for the solenoid-shifted starters. 1 1 Share this post Link to post Share on other sites
