Monstrosity 1,153 #1 Posted May 8, 2022 (edited) Hello! Brand new picked up a 1277 yesterday and it needs some help. It has no belts, a missing PTO and lever, the main drive cover, and the main drive belt is what I'm trying to figure out how it's routed. Does anyone have pictures of there drive belt with the cover off? Ive searched the forum with no luck maybe I didn't see it but I couldn't find anything. Thanks! Edited May 8, 2022 by Monstrosity Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #2 Posted May 8, 2022 Welcome to Red Square 1 Share this post Link to post Share on other sites
WHX?? 58,218 #3 Posted May 8, 2022 P Belt routing is fairly simple. Just up over the top of the clutch idler. You'll need to find a belt guard they are essential in stopping the belt. 1 Share this post Link to post Share on other sites
8ntruck 9,307 #4 Posted May 8, 2022 to the forum. Bunch of good, helpful, folks here. Collectively, we've probably broken, and fixed just about anything that can go wrong on a Wheel Horse. The belt guard has some sheet metal tabs on the inside near the engine pulley. These tabs hold the belt off of the pulley when the clutch is depressed and the belt is slack. Without the guard, the slack belt will contact the pulley just enough to keep the input shaft in the transmission turning, which will prevent you from changing gears. Good luck and have fun with your new Horse. 2 1 Share this post Link to post Share on other sites
WHX?? 58,218 #6 Posted May 8, 2022 (edited) 5 hours ago, WHX?? said: Just up over the top of the clutch idler. My bad I was thinkin gear jammer..... here ya go....a 1077 but same difference Belt is a WH 6489 or a 7927or a 4L78 inch belt. I'm partial to the TSC belts. Here's the chart that belt size came off of. Every horse person worth their red should have this. Chart Belts Tractor drive belt charts _492-0392.pdf Edited May 8, 2022 by WHX?? 2 Share this post Link to post Share on other sites
Monstrosity 1,153 #7 Posted May 8, 2022 Thank you all!! 2 Share this post Link to post Share on other sites
