Wheelhorse#1 1,896 #1 Posted May 8, 2022 I want to wire up a couple of lights for a 74 B80.Do I need to change the switch with accessory terminal or can I come straight off the battery with a fuse ? Share this post Link to post Share on other sites
Achto 30,872 #2 Posted May 8, 2022 18 minutes ago, Wheelhorse#1 said: Do I need to change the switch with accessory terminal or can I come straight off the battery with a fuse ? Wiring direct to the battery will be fine. You could also tap into the wire that is hot when the switch is on, should be the wire that goes from the switch to the regulator. If you choose this route then there will be no risk of leaving the lights on with the key switch off. 2 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,896 #3 Posted May 8, 2022 Great thanks I’ll go that route from the regulator,no chance of leaving them on accidentally and coming back to a dead battery. 1 1 Share this post Link to post Share on other sites
