happyhunter63 1 #1 Posted April 24, 2022 New to site I have a c-125 that does not start cranks over. have 11.6 volts to the coil but still no spark at the plug any help would be helpful 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #2 Posted April 24, 2022 Check the points and sand them. Share this post Link to post Share on other sites
Ed Kennell 44,693 #4 Posted April 24, 2022 (edited) 1 hour ago, Maxwell-8 said: Check the points and sand them. Then set the gap to 0.020". Then install a new plug and condensor and report back. Oh, and to the Happy. Edited April 24, 2022 by Ed Kennell Share this post Link to post Share on other sites
happyhunter63 1 #5 Posted April 24, 2022 3 hours ago, Maxwell-8 said: Check the points and sand them. did that and regap them Share this post Link to post Share on other sites
tunahead72 2,601 #6 Posted April 25, 2022 4 hours ago, happyhunter63 said: ... have 11.6 volts to the coil but still no spark at the plug ... I'm assuming you're using a multimeter of some sort, what's the voltage at the battery? And were you testing the voltage to the coil with the ignition in "run"? And what did you use to sand your points? And welcome aboard! Share this post Link to post Share on other sites
