Fishroe 261 #1 Posted April 20, 2022 (edited) What are the first 2 things on the ground found it. Cutter bar and harrow are they wheel horse brand? Edited April 20, 2022 by Fishroe Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #2 Posted April 20, 2022 Spike tooth drag harrows https://www.wheelhorseforum.com/search/?&q=spike tooth&type=downloads_file&search_and_or=or&sortby=relevancy Sickle bar mowers https://www.wheelhorseforum.com/search/?&q="mower sickle side"&type=downloads_file&search_and_or=or&sortby=relevancy 1 Share this post Link to post Share on other sites
Fishroe 261 #3 Posted April 20, 2022 Do the drag harrows work good if you add weights Share this post Link to post Share on other sites
953 nut 68,491 #4 Posted April 20, 2022 (edited) On 4/20/2022 at 4:15 PM, Fishroe said: Do the drag harrows work good if you add weights The drag harrow is used to remove clumps of grass and rocks from plowed soil, added weight wouldn't be an advantage. This is from a 1963 advertisment for the 953. Edited April 23, 2022 by 953 nut 2 Share this post Link to post Share on other sites
John2189 599 #5 Posted April 23, 2022 Sickle mower does not have the drive Share this post Link to post Share on other sites
