Dave 1953 70 #1 Posted April 15, 2022 I failed to mention the Fram, Wix, Napa p/n for the right hydro filter for the GT14.. Probably the same one that goes on all my older Cub Cadet hydros but I want to make sure while I'm changing everything out and about how much fluid is required with a change with all new hoses and filter. Thanks in advance. Share this post Link to post Share on other sites
953 nut 62,977 #2 Posted April 15, 2022 Your transmission uses the WIX 51410 or NAPA 1410 filter and you will need a gallon of fluid. 2 Share this post Link to post Share on other sites
WHX?? 53,284 #3 Posted April 15, 2022 25 minutes ago, 953 nut said: need a gallon of fluid. Maybe a even tad more. Some of the purists like to use the original 5990 filter which are widely available but cashy. No idea who makes them ....Stens? https://www.amazon.com/79-5270-Toro-Assembly-106-5830-H25W3308737/dp/B01LXMO7V7 Share this post Link to post Share on other sites
squonk 44,859 #4 Posted April 15, 2022 Makes little sense to insist on the Toro filter unless your already at a dealer getting other stuff. My Toro dealer (now closed) wouldn't even stock them. He got them from me when I worked at Napa. (pictures of Toro filter cut open in this thread.) Share this post Link to post Share on other sites
JoeM 9,302 #5 Posted April 15, 2022 2 hours ago, WHX?? said: purists like to use the origina A little black matte spray paint on the napa filter and you got the best of both worlds. 2 Share this post Link to post Share on other sites
Dave 1953 70 #6 Posted April 16, 2022 I will just stick with the Wix or Napa, both available in my little town.I like to keep stuff that you see as close as possible to original. Now if it was going across the block at Barrett Jackson and they were switching to the underside cam as it was being driven up on the block and showing the whole world what the bottom looked like maybe I might go with a repopped original type.:) Shoot, I don't even use a repopped Mopar oil filter on my '70 Coronet R/T that's pictured on my post, I use a Fram because it looks good next to the orange engine and exterior orange paint. 2 Share this post Link to post Share on other sites
