Wheelhorse#1 1,901 #1 Posted April 15, 2022 (edited) Anyway to make this work for a WH? OD is 1” to 1/8 on the tapered part It’s a Briggs 8hp. Edited April 15, 2022 by Wheelhorse#1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted April 15, 2022 The 1" diameter crankshafts were used on the B&S engines, 8hp Kohler engines and the first 10hp Kohler models. The rest used 1-1/8" diameter crankshafts. I do not know how that step in the shaft will affect that. Is it 1-1/8" diameter? Could one use the 1-1/8" transmission drive pulley with the 1" pto inner race? This engine has a thrust bearings to support a manual pto but do not know if the engine case is strong enough so an electric clutch may be necessary. https://www.partstree.com/models/190432-6035-01-briggs-stratton-horizontal-engine/ Share this post Link to post Share on other sites
953 nut 64,116 #3 Posted April 15, 2022 There are tapered shaft adapters out there to allow you to use a straight shaft pulley on a tapered shaft. Take a look at these. https://www.google.com/search?q=tapered+shaft+adapter&rlz=1C1JZAP_enUS981US981&sxsrf=APq-WBtG2RZXYX2dONefxo3T4caeiYQLkA%3A1650020609434&ei=AVFZYtuPGtu4tQbGvaOQAw&ved=0ahUKEwiblLDi9ZX3AhVbXM0KHcbeCDIQ4dUDCA4&oq=tapered+shaft+adapter&gs_lcp=Cgdnd3Mtd2l6EAxKBAhBGABKBAhGGABQAFgAYABoAHAAeACAAQCIAQCSAQCYAQA&sclient=gws-wiz 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #4 Posted April 15, 2022 (edited) Great thanks for your alls input.I have a 71 800 special with a similar Briggs a 71 that Is original to this WH. Ill have to look but I don’t believe it has the taper at the end.and Not sure if it’s going to be long enough. My thought was to use manual PTO and the Gen start .I’m thinking I could swap everything over from the old Briggs to the new engine. Pic of the ,engine I want to replace . I use it to cut grass,still runs,knocks and smokes like crazy only a matter of time 💥.It’s already been bored out has a 0.30 piston in it. The other motor is bran new with no hrs on it. I know the 800 specials aren’t highly sought after with the peerless trans and all,mainly grass cutter but it really is one of my favorite tractors to cut the lawn with and the trans works fine. Edited April 15, 2022 by Wheelhorse#1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #5 Posted April 15, 2022 Sorry did not realize the last 3" was tapered. 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #6 Posted April 15, 2022 (edited) 10 hours ago, 953 nut said: There are tapered shaft adapters out there to allow you to use a straight shaft pulley on a tapered shaft. Take a look at these. https://www.google.com/search?q=tapered+shaft+adapter&rlz=1C1JZAP_enUS981US981&sxsrf=APq-WBtG2RZXYX2dONefxo3T4caeiYQLkA%3A1650020609434&ei=AVFZYtuPGtu4tQbGvaOQAw&ved=0ahUKEwiblLDi9ZX3AhVbXM0KHcbeCDIQ4dUDCA4&oq=tapered+shaft+adapter&gs_lcp=Cgdnd3Mtd2l6EAxKBAhBGABKBAhGGABQAFgAYABoAHAAeACAAQCIAQCSAQCYAQA&sclient=gws-wiz Thank you for the link.I’m hopeful I can make it work.Just need to take a closer look. Of not I’ll go with a Kohler Edited April 15, 2022 by Wheelhorse#1 1 Share this post Link to post Share on other sites
