peter lena 9,779 #1 Posted April 14, 2022 just reading the regular , problems with attempted stuck hubs , more often then not , what I see is the loss of direction to removal force , regularly to the outer edge of the frozen hub, having this type of central pull point https://www.bing.com/images/search? will get you quicker results . used them for years on brutal stuff , strength to strength , with a small hydraulic hand pump , worth a look .pete 1 1 Share this post Link to post Share on other sites
Handy Don 15,997 #2 Posted April 14, 2022 (edited) 44 minutes ago, peter lena said: just reading the regular , problems with attempted stuck hubs , more often then not , what I see is the loss of direction to removal force , regularly to the outer edge of the frozen hub, having this type of central pull point https://www.bing.com/images/search? will get you quicker results . used them for years on brutal stuff , strength to strength , with a small hydraulic hand pump , worth a look .pete Just adding a thought here. It might not be worth the money to own one of these infrequently used but "might be perfect for the job" tools, but they are borrowable and rentable--check your local auto parts store(s) or other tool rental shop. (google "bearing puller rental near me") Edited April 14, 2022 by Handy Don 1 1 Share this post Link to post Share on other sites
lynnmor 8,644 #3 Posted April 14, 2022 Some Wheel Horse models use a thick plastic washer behind the hub, that puller will instantly destroy the washer. Some other models have a considerable distance that would need spacers for the puller to work. And then there is the fact that it has only a small amount of movement. Share this post Link to post Share on other sites
Handy Don 15,997 #4 Posted April 14, 2022 (edited) 6 minutes ago, lynnmor said: Some Wheel Horse models use a thick plastic washer behind the hub, that puller will instantly destroy the washer. Some other models have a considerable distance that would need spacers for the puller to work. And then there is the fact that it has only a small amount of movement. Yep, all great points. There is no "one size fits all" tool, for sure! Tweaked my post to clarify. Edited April 14, 2022 by Handy Don 1 Share this post Link to post Share on other sites
