wheelwhores 107 #1 Posted April 13, 2022 Found a nice 2 stage blower for relatively cheap 'nearby', wondering if this will fit my c175 Share this post Link to post Share on other sites
wheelwhores 107 #2 Posted April 13, 2022 I haven't found a good attachment compatibility list yet, all those I found were difficult to cross-reference. So if anyone has a good one please provide that as well! Share this post Link to post Share on other sites
WHX?? 57,397 #3 Posted April 13, 2022 This interchange chart says no, only 3,4 & 500 series '90 and up. WH Interchange 1955-2000 (1).pdf Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,357 #4 Posted April 13, 2022 You will not find that info in a chart because they did not have a 2-stage model until 1990. It should fit through - the single stage does. 1 Share this post Link to post Share on other sites
squonk 47,405 #5 Posted April 13, 2022 I think the hood hangs over more on the front Black hoods. That would be the only reason I could think of where you'd MAYBE have an issue. 1 Share this post Link to post Share on other sites
WHX?? 57,397 #6 Posted April 13, 2022 You might be onto something Squonky. Belts might not line up and lift bar issues. It just might work with some monkeyin around. Share this post Link to post Share on other sites
squonk 47,405 #7 Posted April 13, 2022 On Marvin with the single stage the belt just missed the side of the hood. I don't have a picture on the right side with a blower but you can see how close the belt is on a genny set up. 1 Share this post Link to post Share on other sites
mrc 1,103 #8 Posted April 14, 2022 hello wheelwhores squonk is correct. a couple years ago another member (do not recall his name) had this same issue. trying to marry a 2 stager with a blackhood. he ended up changing the hood so the belt would not rub on the blackhood hood. perhaps a search on here might yield that thread 1 Share this post Link to post Share on other sites
