Kelsey 91 #1 Posted April 10, 2022 Greetings, I stopped in at Advanced Auto for a NGK B-LM spark plug and I bought a NGK B-2. Can the Latter be used in place of the original plug? What is the difference between the two? The newer one is a bout 1/2" taller. Thanks, Kelsey Share this post Link to post Share on other sites
squonk 45,526 #2 Posted April 10, 2022 Height is about it. Run it! Share this post Link to post Share on other sites
Kelsey 91 #3 Posted April 12, 2022 Does anyone have concise answers to my questions? Share this post Link to post Share on other sites
squonk 45,526 #4 Posted April 12, 2022 (edited) I checked all the specs. You can run it. Heat range, reach threads, gasket, all the same. B-2 Brand: NGK Contents: Nickel tipped spark plug w/gasket Electrode Core Material: Copper Gap Size: 0.028 in Hex Size: 13/16 in Manufacturer: NGK Spark Plug Manufacturer Part Number: B-2 SDS Required: No Seat Type: Flat Spark Plug Heat Range: NGK2 Spark Plug Hex Size: 5/8 in. Spark plug Inductive: No Spark Plug Reach: 9.5 mm Spark Plug Resistor: No Spark Plug Seat Type: Gasket Spark Plug Thread Size: 14 mm Terminal Type: Loose Thread Size: M14-1.25 B2-LM Brand: NGK Contents: Nickel tipped spark plug w/gasket Electrode Core Material: Copper Gap Size: 0.028 in Hex Size: 13/16 in Manufacturer: NGK Spark Plug Manufacturer Part Number: B2LM SDS Required: No Seat Type: Flat Spark Plug Heat Range: NGK2 Spark Plug Hex Size: 13/16 in. Spark plug Inductive: No Spark Plug Reach: 9.5 mm Spark Plug Resistor: No Spark Plug Seat Type: Gasket Spark Plug Thread Size: 14 mm Terminal Type: Loose Thread Size: M14-1.25 Edited April 12, 2022 by squonk Share this post Link to post Share on other sites
Kelsey 91 #5 Posted April 12, 2022 Thanks Mike! The old plug was in my son's magnum 10HP. Advanced Auto salesman couldn't elaborate on the new plug. Curiosity got the best of me to ask, internet wasn't all that helpful except for a few things. Share this post Link to post Share on other sites
peter lena 9,764 #6 Posted April 12, 2022 @Kelsey spark plugs are run , by related wiring , make sure every connection is solid , typically add light swipe of dielectric grease , inside of the spark plug boot , makes installation smooth and ensures conductivity . look over each wire run , just a suggestion , pete Share this post Link to post Share on other sites
Kelsey 91 #7 Posted April 12, 2022 2 hours ago, peter lena said: @Kelsey spark plugs are run , by related wiring , make sure every connection is solid , typically add light swipe of dielectric grease , inside of the spark plug boot , makes installation smooth and ensures conductivity . look over each wire run , just a suggestion , pete Thanks Pete! Just so the WH forum knows, I changed out the plug, air filter, fuel filter and used fresh non-ethanol gasoline in my boy's wheel horse. She did a heck of a job for the first mowing of the season. Sure beats a herd of goats. 1 Share this post Link to post Share on other sites
peter lena 9,764 #8 Posted April 12, 2022 @Kelsey glad to hear you did a thorough job on that , thats the way to kill a problem ! usually a number of things related to issue , you hit them all , now about those goats , good going , pete Share this post Link to post Share on other sites
