sodapop 2 #1 Posted April 8, 2022 I have a 312 – 8 wheel horse tractor 1986, I need a steering wheel ,mine is broken... Share this post Link to post Share on other sites
Lee1977 7,458 #2 Posted April 8, 2022 You could call or email A-Z Tractor, located down in the venders section. Good man to deal with. I've bought serval used parts there and they were all good. 1 Share this post Link to post Share on other sites
sodapop 2 #4 Posted April 8, 2022 Where is the vendor section Share this post Link to post Share on other sites
953 nut 63,072 #5 Posted April 8, 2022 here is a link to the A-Z website, https://a-ztractor.com/. Removing a steering wheel can be quite a chore but since yours is broken your options are a bit easier. Share this post Link to post Share on other sites
SylvanLakeWH 29,881 #6 Posted April 8, 2022 Sounds like they’ve got you covered… Good luck on removal! Share this post Link to post Share on other sites
oliver2-44 11,071 #7 Posted April 9, 2022 Post a picture of how it’s broken. I repaired the one on my C81 about 3 years ago and still holding. Share this post Link to post Share on other sites
roadapples 6,985 #8 Posted April 9, 2022 If you can wait till June, you should come to the Big Show. Plenty to choose from and good prices. And 2 Share this post Link to post Share on other sites
Pullstart 68,532 #9 Posted April 9, 2022 to our newest member @sodapop! Share this post Link to post Share on other sites
sodapop 2 #10 Posted April 9, 2022 Thanks everyone ☺️ Share this post Link to post Share on other sites
sodapop 2 #11 Posted April 9, 2022 (edited) Here is a couple pics.of my 1986 312-8 ,,,it has never sat outside, always garage kept ,no rust any where... Edited April 9, 2022 by sodapop 1 Share this post Link to post Share on other sites
johnnymag3 2,633 #12 Posted April 9, 2022 Looks like you may need a new tube also........Nice looking 312 !!! Share this post Link to post Share on other sites
SylvanLakeWH 29,881 #13 Posted April 9, 2022 Looks bent. Is it “broke” as well? As in, does not function? If just bent, I’m thinking it could be bent back…? Share this post Link to post Share on other sites
sodapop 2 #14 Posted April 9, 2022 It still works, I can use it, but it's like half of it is real loose, the other half is stiff, it must have broke inside the plastic, there must be metal inside or something.. Share this post Link to post Share on other sites
Handy Don 15,222 #15 Posted April 9, 2022 (edited) Yep 53 minutes ago, sodapop said: ...it must have broke inside the plastic, Yep, plastic molded around metal. Likely the inner bar is broken on one side. Check in our vendor section. At least a couple of them are likely able to fix you up with a new one. Also, search for some of the old threads that discuss removing these steering wheels--they use a roll pin and if they are rusted...well, they can be tough to remove! Edited April 9, 2022 by Handy Don 1 Share this post Link to post Share on other sites
Bill D 2,442 #16 Posted April 9, 2022 Take the center cap off and start soaking the shaft and spiral pin with penetrating oil. Consider installing a 15", 3 spoke wheel from a 417 if you can get one. I like the feel of the larger wheel and it makes steering easier. 1 1 Share this post Link to post Share on other sites
johnnymag3 2,633 #17 Posted April 9, 2022 (edited) If its that bad......just cut the center and remove it....then the pin will be easy to deal with. I have a wheel if you want to buy one. There are a few on Stealbay also. Bill D has a way to make new tubes also....the part under the steering wheel Edited April 9, 2022 by johnnymag3 1 Share this post Link to post Share on other sites
sodapop 2 #18 Posted April 9, 2022 How do I get to the vendor section Share this post Link to post Share on other sites
Handy Don 15,222 #19 Posted April 9, 2022 Top of the page under Classifieds. 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,881 #20 Posted April 9, 2022 https://www.wheelhorseforum.com/forum/92-vendors/ Share this post Link to post Share on other sites
johnnymag3 2,633 #21 Posted April 14, 2022 I left you a PM....I have the same wheel for you...…. John Share this post Link to post Share on other sites
