Jacob S 67 #1 Posted April 3, 2022 On my Kohler K181 I’ve been trying to adjust the governor because the engine revs up all the way and I don’t think that is too good for it. How do you adjust it properly? 1 Share this post Link to post Share on other sites
WHX?? 55,005 #2 Posted April 3, 2022 Page 5-1 in the manual. Kohler_K91_K141_K161_K181_K241_K301_K321_Serv_Man_0472.pdf 1 1 Share this post Link to post Share on other sites
squonk 45,527 #3 Posted April 3, 2022 You need to make sure your governor gear shaft tab isn't broken. There has been a lot of that goin on this past year. Look into the link Jim gave you. When adjusting the shaft you turn the shaft counter clockwise. It must stop against the governor gear inside. If it doesn't stop your shaft tab is broken and the engine must be completely torn down. 1 1 Share this post Link to post Share on other sites
Handy Don 15,945 #4 Posted April 3, 2022 (edited) 1 hour ago, squonk said: When adjusting the shaft you GENTLY BUT FIRMLY turn the shaft counter clockwise It is possible to break the tab by forcing this! Edited April 3, 2022 by Handy Don 3 Share this post Link to post Share on other sites
Jacob S 67 #5 Posted April 3, 2022 It’s definitely not broken it stops at the gear Share this post Link to post Share on other sites
