RITEK 25 #1 Posted April 2, 2022 PXL_20220402_202634630.mp4 Share this post Link to post Share on other sites
lynnmor 8,626 #2 Posted April 2, 2022 Looks like you are supplying power to the solenoid but not to the motor. Share this post Link to post Share on other sites
RITEK 25 #3 Posted April 2, 2022 5 minutes ago, lynnmor said: Looks like you are supplying power to the solenoid but not to the motor. How do I fix that Because this starter ran.my battery dead and wouldnt start the tractor any more Share this post Link to post Share on other sites
Handy Don 15,944 #4 Posted April 2, 2022 Those little test leads cannot carry enough current to spin the starter motor. To really show what's happening, you must connect it to a battery (to both the + and the -) with heavier wire and then activate the solenoid to "switch the motor on". Not sure what you mean by "starter ran.my battery dead and wouldnt start the tractor any more" means. Did the engine crank and not start until the battery was exhausted? Did the starter click but not turn over the engine? Share this post Link to post Share on other sites
RITEK 25 #5 Posted April 2, 2022 Just now, Handy Don said: Those little test leads cannot carry enough current to spin the starter motor. To really show what's happening, you must connect it to a battery (to both the + and the -) with heavier wire and then activate the solenoid to "switch the motor on". Not sure what you mean by "starter ran.my battery dead and wouldnt start the tractor any more" means. Did the engine crank and not start until the battery was exhausted? Did the starter click but not turn over the engine? The starter would just click. I was plowing snow one day with my tractor and I noticed my gauge was dropping charge so I shut it off put it away for a bit then came back out. Started it up ran it for a bit then shut it off but then it wouldn't start. So I charged the battery for 20min on 40amp then tried to start it on 200amp wouldn't. Unless I kept turning the key quick then it would do something. So I finally got to the starter cleaned the whole insides sanded everything and still nothing. Share this post Link to post Share on other sites
Handy Don 15,944 #6 Posted April 2, 2022 Couple of things come to mind.... I'll give you long odds that your starter isn't the problem. Your battery is not charging and not holding a charge. The likeliest cause of that is an aged or damaged battery--the only way to be sure is to get it load checked (NAPA or other battery service station you trust) and replace if needed. A bad battery cannot be charged--it must be replaced. A 520-HC will not start or run for long on a bad battery. Why isn't the battery charging in the tractor? Likeliest cause is bad connections in the wiring somewhere. Small chance that the voltage regulator has failed. Go over all the wiring, clean all the connections everywhere, including all the grounds, and vaseline or dielectric grease them all when reassembling. Then, put in a known good battery and try starting and then look to see if the voltage is up over 14 charging. Do you have and know how to use a multi-meter? Checking circuits is the next step if the above steps don't work. Share this post Link to post Share on other sites
RITEK 25 #7 Posted April 2, 2022 3 minutes ago, Handy Don said: Couple of things come to mind.... I'll give you long odds that your starter isn't the problem. Your battery is not charging and not holding a charge. The likeliest cause of that is an aged or damaged battery--the only way to be sure is to get it load checked (NAPA or other battery service station you trust) and replace if needed. A bad battery cannot be charged--it must be replaced. A 520-HC will not start or run for long on a bad battery. Why isn't the battery charging in the tractor? Likeliest cause is bad connections in the wiring somewhere. Small chance that the voltage regulator has failed. Go over all the wiring, clean all the connections everywhere, including all the grounds, and vaseline or dielectric grease them all when reassembling. Then, put in a known good battery and try starting and then look to see if the voltage is up over 14 charging. Do you have and know how to use a multi-meter? Checking circuits is the next step if the above steps don't work. I have put a brand new battery and went over the procedures to check the start like putting 200 straight amps to it. Share this post Link to post Share on other sites
Handy Don 15,944 #8 Posted April 2, 2022 (edited) Have you checked all the wiring and all the ground connections? A bad 12v connection cannot be overcome by adding "amps". Edited April 2, 2022 by Handy Don Share this post Link to post Share on other sites
RITEK 25 #9 Posted April 2, 2022 9 minutes ago, Handy Don said: Have you checked all the wiring and all the ground connections? A bad 12v connection cannot be overcome by adding "amps". No bad connections Share this post Link to post Share on other sites
lynnmor 8,626 #10 Posted April 2, 2022 33 minutes ago, RITEK said: I have put a brand new battery and went over the procedures to check the start like putting 200 straight amps to it. You need to back up and quit abusing the battery, starter, voltage regulator, switches and wiring. 200 amps, you got to be kidding. Follow what Don has been trying to tell you and test the battery and charging system. Did you know that it takes 10 hours or more to properly charge a battery? Share this post Link to post Share on other sites
RED-Z06 2,716 #11 Posted April 3, 2022 Onans in general can get into something called "click, click, start" where the solenoid clicks a few times then engages, its from low power to the solenoid. But if you are putting power right in directly...probably not the case Share this post Link to post Share on other sites
