ri702bill 12,418 #1 Posted March 29, 2022 (edited) The original 5025 Unidrive on my 502 roller was completely full of water when I got it 8 or so years ago - what was left of the shifter boot looked like a used-up faucet washer, so I scrounged thru the "Parts Department" and came up with 2 potential candidates. It is not easy to find a 110-volt motor that has reversable rotation. My other 2 choices were to find a double shaft version, or to overhang mount the motor off the frame - not a good choice. I did find one off of the Shopsmith Mk 5' complete with 3 prong plug and an On/Off switch - and it did have 2 additional wires with Fast-ons - switched them and it now runs CCW. (like an electric Kohler!!) The first Unidrive had noise issues and 4 leaking seals; after 2 flushes it got no better. The second one as shown was quiet and had 2 leaking seals. Drained what oil was in there, raising the front of the frame. Set the front back down, added 2 quarts of Diesel fuel thru the shifter hole and ran it on low speed thru all 4 gears, 10 minutes apiece. Repeated using the middle step and the largest step. Drained that, ready for new seals. If you think you MAY have a seal that is leaking, the thin Diesel fuel will let you know very quickly... Edited March 29, 2022 by ri702bill 10 5 Share this post Link to post Share on other sites
peter lena 9,937 #2 Posted March 29, 2022 @ri702bill terrific opportunity thought ! what a concept ! love the idea of road testing and verifying an improvement . like to look at intended operational function , and improve on that . very often just a small detail change makes it function so much better.. on my road flush drives , been using ATF fluid as a cleaner fluid , think it does a very thorough flush and drain down . keep it oily , pete 2 1 Share this post Link to post Share on other sites
ri702bill 12,418 #3 Posted March 29, 2022 2 minutes ago, peter lena said: been using ATF fluid as a cleaner fluid And is probably cost effective too - I paid $5.19 for a gallon of Diesel the other day. Bill 2 Share this post Link to post Share on other sites
WHX?? 57,315 #4 Posted March 29, 2022 You got it stripped down that far Bill I would be tempted to split it and check things out. 4 2 Share this post Link to post Share on other sites
peter lena 9,937 #5 Posted March 29, 2022 @ri702bill being a lubrication nut , regularly look for lubrication / change results to any lubricant . if it works better smoother . easier and lasts longer , why not go that way ? pete 1 Share this post Link to post Share on other sites
ri702bill 12,418 #6 Posted March 29, 2022 5 minutes ago, WHX?? said: I would be tempted to split it and check things out. @WHX?? I might just do that with the noisy one first - never had the need to open one up - yet .... Bill 2 Share this post Link to post Share on other sites
Pullstart 70,486 #7 Posted March 29, 2022 Could you have twisted a longer belt? Regardless I’m glad this isn’t a toilet or a plunger thread! 1 2 Share this post Link to post Share on other sites
ri702bill 12,418 #8 Posted March 29, 2022 1 hour ago, Pullstart said: Could you have twisted a longer belt? Like an old Corvair??? No toilet humor here - yet - not by me 1 Share this post Link to post Share on other sites
Pullstart 70,486 #9 Posted March 29, 2022 8 minutes ago, ri702bill said: Like an old Corvair??? Yeah. Share this post Link to post Share on other sites
stevasaurus 23,739 #10 Posted March 29, 2022 Actually, all you had to do, turn the motor around so the pulley is lined up and the motor is on the right side. Or figure "8" a fan belt, like Kevin said. 4 Share this post Link to post Share on other sites
ebinmaine 79,550 #11 Posted March 29, 2022 4 hours ago, ri702bill said: If you think you MAY have a seal that is leaking You probably do and you should replace it anyways. 4 hours ago, WHX?? said: You got it stripped down that far Bill I would be tempted to split it and check things out. 3 hours ago, ri702bill said: @WHX?? I might just do that with the noisy one first - never had the need to open one up - yet .... Bill I wouldn't be just tempted Jim. I would have already started by now... Bill, go ahead and pop that thing open. Pretty interesting stuff inside there. No toilet valves mind you, but still pretty interesting stuff. 1 1 Share this post Link to post Share on other sites
ri702bill 12,418 #12 Posted March 29, 2022 36 minutes ago, ebinmaine said: I would have already started by now... OK just need to get a 3912 gasket ..... 2 Share this post Link to post Share on other sites
wallfish 20,160 #13 Posted March 29, 2022 7 hours ago, ri702bill said: It is not easy to find a 110-volt motor that has reversable rotation. True! Where did you find that one or was it something you already had? I don't think it would hurt the trans to run it in reversed rotation. Might even help to run it both directions when cleaning it out too. 4 Share this post Link to post Share on other sites
stevasaurus 23,739 #14 Posted March 29, 2022 It shouldn't hurt the trans to run it in the opposite direction, but if you look down the shifter hole when running it in the counter-clock-wise direction, you will get the appreciation for how the transmission oils itself. It is worth the look !! 4 1 1 Share this post Link to post Share on other sites
ri702bill 12,418 #15 Posted March 29, 2022 1 hour ago, wallfish said: Where did you find that one or was it something you already had? Yup - the Parts Department coughed up a worthy motor...from the "I just MAY have a use for this thing, but not just now, I'll leave it here shelf !! Bill 1 4 Share this post Link to post Share on other sites
Wheelhorse#1 1,953 #16 Posted March 30, 2022 Great idea.Thinking outside of the box.That should of really got the juices flowing ! 3 Share this post Link to post Share on other sites
wallfish 20,160 #17 Posted March 30, 2022 5 hours ago, stevasaurus said: It shouldn't hurt the trans to run it in the opposite direction, but if you look down the shifter hole when running it in the counter-clock-wise direction, you will get the appreciation for how the transmission oils itself. It is worth the look !! Is this like telling the kids to look in the end of the garden hose to tell me when the water is coming out? LoL 6 1 Share this post Link to post Share on other sites
Pullstart 70,486 #18 Posted March 30, 2022 12 minutes ago, wallfish said: Is this like telling the kids to look in the end of the garden hose to tell me when the water is coming out? LoL I could still use that one! Maybe not with my kids, but surely with my inlaw’s kids! 2 1 Share this post Link to post Share on other sites
Handy Don 16,918 #19 Posted March 30, 2022 (edited) Hey @davem1111, check out the top of this thread. Got a spare motor to hook up to test your 700? Edited March 30, 2022 by Handy Don 2 1 Share this post Link to post Share on other sites
gt14rider 1,227 #20 Posted March 30, 2022 Just turn motor around to change direction, short belt,just let motor hang for tension. 4 Share this post Link to post Share on other sites
stevasaurus 23,739 #21 Posted March 30, 2022 This is from 2011...Brrly1's #5007 tranns. 6 Share this post Link to post Share on other sites
davem1111 2,282 #22 Posted April 3, 2022 On 3/29/2022 at 10:17 PM, Handy Don said: Hey @davem1111, check out the top of this thread. Got a spare motor to hook up to test your 700? Unfortunately I do not... probably should have pulled the motor from the old wash machine before scrapping it last year. I love ideas like this, and the challenges that prompt our brains to come up with them. 2 Share this post Link to post Share on other sites
Handy Don 16,918 #23 Posted April 3, 2022 (edited) Be thankful, @davem1111, that you clearly do not have the "I can't throw that out, it might be useful someday" disease. Me, I'm sitting on three old motors (one with a switch for forward and reverse!) that I've been hanging onto "just in case" right next to a big box of scrap metal that I very occasionally mine for some project or repair. Something's gotta give here. Edited April 3, 2022 by Handy Don 1 Share this post Link to post Share on other sites
davem1111 2,282 #24 Posted April 3, 2022 7 minutes ago, Handy Don said: Be thankful, @davem1111, that you clearly do not have the "I can't throw that out, it might be useful someday" disease. Me, I'm sitting on three old motors (one with a switch for forward and reverse!) that I've been hanging onto "just in case" right next to a big box of scrap metal that I very occasionally mine for some project or repair. Something's gotta give here. Actually, I *do* have more than a mild case of that disease, but when my wife looks around the garage (which doesn't happen very often), there usually has to be some at least "token" sacrifice... 1 2 Share this post Link to post Share on other sites
stevasaurus 23,739 #25 Posted April 3, 2022 No problem, if you do not have a motor. You can use your horse. Share this post Link to post Share on other sites
