snowhound 106 #1 Posted March 20, 2022 I just got a 310-8 with a k series engine that the wiring has been butchered I don't know the year but I think only the 1985 and 1986 had K series. It was repainted over all the decals so I asume it is a 310 becaune it has a 10hp engine and 6" front rims. I'm looking for a wiring diagram I've looked in wiring demystification guide and didn't find one. Share this post Link to post Share on other sites
pfrederi 19,247 #2 Posted March 20, 2022 use the second file for 3 amp first for 15 amp 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,844 #3 Posted March 20, 2022 The 1986 model was the first year for the low oil switch in the oil pan. Here is the 1985 wiring 4 Share this post Link to post Share on other sites
AHS 1,566 #4 Posted March 25, 2022 The 85 and 86 look different. I have an 85 310. 1 Share this post Link to post Share on other sites
Harpkatt 1 #5 Posted March 28, 2022 So here's my first post, it's related to this diagram. I picked up my first WH last week, It started straight away but then my second attempt would not start. I disconnected the harness and jumped the starter and she fired right off. Obviously proving the engine runs. My issue is with spark. When I used the key to try to test spark with the harness connected I found while cranking there is no spark; the moment I let off the key I saw spark at the plug. This while the engine was still rotating from momentum. Any thoughts? Share this post Link to post Share on other sites
953 nut 63,001 #6 Posted March 28, 2022 Please give us a bit more information. What year, model and model number are you having problems with? Was your PTO off and were you in the seat at the time? You probably should start your own thread, just click on this link and tell us about the situation you find yourself in. https://www.wheelhorseforum.com/forum/3-wheel-horse-tractors/?do=add Share this post Link to post Share on other sites
