Rick 55 BB 24 #1 Posted March 18, 2022 Hey guys does anyone know of a place to get an assortment of woodruff keys specific to wheel horse ? I have bought a couple different sets and when I try to use them none seem to fit quite right . when measuring them they are all over the place . Thanks Share this post Link to post Share on other sites
WHX?? 57,470 #2 Posted March 18, 2022 I got mine at HF. it has all of the sizes a uses. 1 1 Share this post Link to post Share on other sites
stevasaurus 23,748 #3 Posted March 18, 2022 Here is a key way list...remember, these are soft metal, you can always file them to fit. 1 Share this post Link to post Share on other sites
Rick 55 BB 24 #4 Posted March 19, 2022 4 hours ago, WHX?? said: I got mine at HF. it has all of the sizes a uses. Yea that's where I got the assortment i have , but not one is the correct size's . I have had to file every one I have used , that's why I was asking about a better quality assortment . Thanks Share this post Link to post Share on other sites
Achto 32,119 #5 Posted March 19, 2022 File to fit ensures a tight fit. 5 Share this post Link to post Share on other sites
Rick 55 BB 24 #6 Posted March 19, 2022 9 minutes ago, Achto said: File to fit ensures a tight fit. Yep that's true , i guess I was looking for a better assortment than what HF has . Today I was working on the motion lever on a c-120 and the through shaft has a small woodruff key in the friction cone that was missing . It took me 45 minutes to grind and file one to fit . I ran into the same thing with the axle to hub keys awhile back . Thanks 1 Share this post Link to post Share on other sites
ebinmaine 79,740 #7 Posted March 19, 2022 9 hours ago, Achto said: File to fit ensures a tight fit. A VERY good pair of locking pliers/Vise grips and a belt sander - used with much care - can help. 14 hours ago, Rick 55 BB said: assortment of woodruff keys specific to wheel horse Not likely something like that exists. Wheelhorse company used many Standard Parts. Nuts, bolts, belts, clips, washers, spacers, bearings, seals, collars, wire holders, wire terminals and so on. .... Woodruff keys too. To get a specific assortment of WH keys I'd think the best bet is to accurately measure each one you remove and get a good replacement from McMaster Carr. Keep the list handy for future reference. The challenge I've noticed is that WH were designed built engineered back 50+ years ago. The "Standard" of Standard Parts has likely changed. 4 Share this post Link to post Share on other sites
953 nut 67,501 #8 Posted March 19, 2022 14 hours ago, Rick 55 BB said: anyone know of a place to get an assortment of woodruff keys specific to wheel horse ? If you go through the IPL for your specific tractor each woodruff key is shown and the size is given. Once you have developed a comprehensive list of all the keys that fit your tractor you could buy them from https://www.mcmaster.com/keys/key-type~woodruff/ 4 Share this post Link to post Share on other sites
squonk 47,423 #9 Posted March 19, 2022 My 73 12 had 2 different size keys in the axles. The original owner said nothing was ever done to them. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,372 #10 Posted March 19, 2022 In the early years the keys were listed as a part number only with no dimensions or Woodruff identification. There was a site with a reverse look-up for part numbers years ago. One could enter a part number and each illustrated parts list would come up with the part description. Most had "key" only but the odd ipl would have dimensions or the Woodruff identifier or a superseded part number one could search so one knew what it was. What I learned was recorded and added to a chart. Keys are sized by the cutter that is used to make the pocket so key size is larger than the actual key. This 3-page chart lists the key size and the actual key dimensions. This 8-page chart lists the Wheel Horse part number and the Woodruff number It was copied from a searchable database but since it is no longer searchable the results are mixed up. You have to look for the correct line. 3 2 Share this post Link to post Share on other sites
pfrederi 20,898 #11 Posted March 19, 2022 There is only on key hard to find that is the axle key on D series GT-14 and i believe 953s #RX Even McMaster doesn't have them. I bought a pack from Fastenal some time ago if anyone needs them... 1 2 1 1 Share this post Link to post Share on other sites
Rick 55 BB 24 #12 Posted March 19, 2022 1 hour ago, gwest_ca said: In the early years the keys were listed as a part number only with no dimensions or Woodruff identification. There was a site with a reverse look-up for part numbers years ago. One could enter a part number and each illustrated parts list would come up with the part description. Most had "key" only but the odd ipl would have dimensions or the Woodruff identifier or a superseded part number one could search so one knew what it was. What I learned was recorded and added to a chart. Keys are sized by the cutter that is used to make the pocket so key size is larger than the actual key. This 3-page chart lists the key size and the actual key dimensions. This 8-page chart lists the Wheel Horse part number and the Woodruff number It was copied from a searchable database but since it is no longer searchable the results are mixed up. You have to look for the correct line. Well thank you , I think this is as close as I have to the dimensions as I will ever get of what I need . I have a guy who repairs my worn out or damaged shafts and hubs , so I will just take the keys along with them and let him machine the keys to fit . I have been doing it myself but with a file and grinder it's time consuming and not as accurate . I bought a dozen # 9 keys for the axles . Thanks again 2 Share this post Link to post Share on other sites
Rick 55 BB 24 #13 Posted March 19, 2022 3 hours ago, 953 nut said: If you go through the IPL for your specific tractor each woodruff key is shown and the size is given. Once you have developed a comprehensive list of all the keys that fit your tractor you could buy them from https://www.mcmaster.com/keys/key-type~woodruff/ Thanks , this is the plan from here on out . thanks for the help 1 Share this post Link to post Share on other sites
Rick 55 BB 24 #14 Posted March 19, 2022 2 hours ago, squonk said: My 73 12 had 2 different size keys in the axles. The original owner said nothing was ever done to them. Yep , I've heard of this before , not sure how that happens , but it does Share this post Link to post Share on other sites
JoeM 10,101 #15 Posted March 19, 2022 I think I may have seen keys at the big show? Grab a hand full of cash and enjoy~ 3 1 Share this post Link to post Share on other sites
WHX?? 57,470 #16 Posted March 19, 2022 (edited) Axle keys should be a #15 https://www.ebay.com/itm/313678277898?hash=item4908aead0a:g:44gAAOSw30hhRLgb Edited March 19, 2022 by WHX?? 2 Share this post Link to post Share on other sites
pfrederi 20,898 #17 Posted March 19, 2022 1 hour ago, WHX?? said: Axle keys should be a #15 https://www.ebay.com/itm/313678277898?hash=item4908aead0a:g:44gAAOSw30hhRLgb Depends on age of tractor older tractors #15 by blackhoods 400 series used #22 1/4 x 1-3/8 300 series mostly #15 2 Share this post Link to post Share on other sites
WHX?? 57,470 #18 Posted March 19, 2022 13 minutes ago, pfrederi said: age of tractor My '60s fetish showing again? 1 Share this post Link to post Share on other sites
ebinmaine 79,740 #19 Posted March 20, 2022 20 hours ago, Rick 55 BB said: . I have a guy who REPAIRS MY WORN OUT OR DAMAGED SHAFTS and hubs , so I will just take the keys along with them and let him machine the @Rick 55 BB Rick if you have someone that can repair an axle shaft you should seriously consider having them cut a full groove in the axle and not use a woodruff key. Switch to 1/4" square key stock and get a full bite in the axle front the hub. IMHO this is one of the very few areas that the Ponds should have done something different. 3 Share this post Link to post Share on other sites
Rick 55 BB 24 #20 Posted March 20, 2022 21 hours ago, WHX?? said: My '60s fetish showing again? 1973 1 Share this post Link to post Share on other sites
Rick 55 BB 24 #21 Posted March 20, 2022 5 hours ago, ebinmaine said: @Rick 55 BB Rick if you have someone that can repair an axle shaft you should seriously consider having them cut a full groove in the axle and not use a woodruff key. Switch to 1/4" square key stock and get a full bite in the axle front the hub. IMHO this is one of the very few areas that the Ponds should have done something different. Yea , we considered it , but he's a bit of a purest about keeping things original . And for what he charges me ,I kind of let him decide what to do . 2 Share this post Link to post Share on other sites
WHX?? 57,470 #22 Posted March 20, 2022 54 minutes ago, Rick 55 BB said: he's a bit of a purest about keeping things original I like him already.... 1 1 Share this post Link to post Share on other sites
Rick 55 BB 24 #23 Posted March 21, 2022 21 hours ago, WHX?? said: I like him already.... He really is a good guy , He has been retired for some time now and does small jobs like this as a hobby to keep himself busy . 1 Share this post Link to post Share on other sites
pfrederi 20,898 #24 Posted March 21, 2022 (edited) You can't trust HF.. several years ago i bought this box of straight keys. But it seemed I always had to do some filing/sanding to get them to fit. Then out of frustration I measured a few.... nice even METRIC dimensions.... Edited March 21, 2022 by pfrederi 1 3 Share this post Link to post Share on other sites
WHX?? 57,470 #25 Posted March 21, 2022 Agreed Paul... when shopping on line one has to be extra careful and be looking for the one's that's listed with ODD metric dim. One nice thing about the custom filing thing is you can get a custom fit for say a marginal keyway. But yes very time consuming. 1 Share this post Link to post Share on other sites
