Burnerman 759 #1 Posted March 18, 2022 Is it possible to change the lift cylinder control valve to one with a “float” position? Share this post Link to post Share on other sites
Handy Don 15,228 #2 Posted March 18, 2022 2 hours ago, Burnerman said: Is it possible to change the lift cylinder control valve to one with a “float” position? I looked long and could not find one that would fit. WH had float-capable valves on two tractors that I know of: the GT 14 (single spool) and the C-195 (single and optional dual spool). Neither valve is a direct swap into a 520H. Note that the 520H uses the Eaton 1100 charge pump for hydraulics and does not have built in pressure relief (as did properly set up Sundstrands in earlier models). The control valve has built in pressure relief. Share this post Link to post Share on other sites
Burnerman 759 #3 Posted March 18, 2022 Thanks. That’s kinda what i figured. ☹️ I did a google search and came up empty but I figured I’d ask. Having float would make plowing with a solid link incredible. 😁 Share this post Link to post Share on other sites
