RED-Z06 2,681 #1 Posted March 14, 2022 Like diameter, length? Cant find that info anywhere. Share this post Link to post Share on other sites
953 nut 62,178 #2 Posted March 14, 2022 If you are looking for external crankshaft measurements I don't know if the service manual would have them by application. Share this post Link to post Share on other sites
RED-Z06 2,681 #3 Posted March 14, 2022 8 hours ago, 953 nut said: If you are looking for external crankshaft measurements I don't know if the service manual would have them by application. Not seeing it in there, but yes pto length and diameter Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,743 #4 Posted March 14, 2022 Diameter will be 1-1/8". Share this post Link to post Share on other sites
JoeM 8,903 #5 Posted March 14, 2022 Like Gary said 1 1/8 diameter. shaft from the seal lip shaft from seal carrier plate front 1 Share this post Link to post Share on other sites
RED-Z06 2,681 #6 Posted March 14, 2022 Darn it...well thanks guys, was hoping it would be the larger diameter, i guess WH used the 1.125 with a sleeve, and some others used the 1.250. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,743 #7 Posted March 14, 2022 None used 1.250" as far as I know. The hardened bearing races used are 1" ID for the B&S engines and Kohler 8hp and smaller plus a few early 10hp Kohlers. All others have 1-1/8" ID. Share this post Link to post Share on other sites
RED-Z06 2,681 #8 Posted March 14, 2022 22 minutes ago, gwest_ca said: None used 1.250" as far as I know. The hardened bearing races used are 1" ID for the B&S engines and Kohler 8hp and smaller plus a few early 10hp Kohlers. All others have 1-1/8" ID. My 12hp Kohler has the hardened race, all WH with the mechanical clutch did i thought. Share this post Link to post Share on other sites
RED-Z06 2,681 #9 Posted March 14, 2022 Just remembered i still have my p220 electric clutch i can measure, seemed big. Share this post Link to post Share on other sites
RED-Z06 2,681 #10 Posted March 14, 2022 (edited) Clutch ID is 1.435" so yeah its quite a bit larger. They call it 1 7/16. Edited March 14, 2022 by RED-Z06 Share this post Link to post Share on other sites
JoeM 8,903 #11 Posted March 14, 2022 1 hour ago, RED-Z06 said: Clutch ID is 1.435" so yeah its quite a bit larger. They call it 1 7/16 Sounds like the size of a Kohler Command Pro 20 / 22 hp that they used in Toro WH XI machines. I might be able to check one tomorrow. Share this post Link to post Share on other sites
RED-Z06 2,681 #12 Posted March 14, 2022 2 minutes ago, JoeM said: Sounds like the size of a Kohler Command Pro 20 / 22 hp that they used in Toro WH XI machines. I might be able to check one tomorrow. Its a beefy shaft, first time I saw it i was in awe. 1 Share this post Link to post Share on other sites
