Bill D 2,595 #1 Posted March 12, 2022 Batting ideas around in my head for a dream build. I know of two Ariens GT 20 tractors near me that I may be able to pick up cheap. Both have full hydro steering. Would an Eaton 1100 be able to power the steering system from one of those tractors and the lift? Transmission in the Ariens is a Sunstrand. I drove one of the Ariens and I love the effortless steering. In addition the M20 in the Ariens could be used on a Wheel Horse if you used an electric PTO clutch. Thoughts? Has anyone done a full hydraulic steering setup on a Wheel Horse? Thanks. 3 Share this post Link to post Share on other sites
pfrederi 19,874 #2 Posted March 12, 2022 Look around i recall someone did it on a D series did away with the mid mount lift and used it for the steering... That would be a Sunstrand piston to piston but i would think an Eaton could do it. M20 is marginally bigger than a M18 but may fit 1 Share this post Link to post Share on other sites
JoeM 9,617 #3 Posted March 12, 2022 (edited) The 522xi machines have Eaton 1100's and power steering with hydro lift works fine. Edited March 12, 2022 by JoeM 1 Share this post Link to post Share on other sites
Pullstart 68,878 #4 Posted March 13, 2022 @JoeM why couldn’t an Eaton 1100 run a loader then? Or could it? Maybe slow and steady? Share this post Link to post Share on other sites
pfrederi 19,874 #5 Posted March 13, 2022 2 hours ago, Pullstart said: @JoeM why couldn’t an Eaton 1100 run a loader then? Or could it? Maybe slow and steady? Volume.... 1 Share this post Link to post Share on other sites
Handy Don 15,933 #6 Posted March 13, 2022 (edited) 2 hours ago, Pullstart said: @JoeM why couldn’t an Eaton 1100 run a loader then? Or could it? Maybe slow and steady? The charge pump is good for only 725psi and 1.3 gpm at that pressure. Some of that is going to charge the drive motor for motion. If you do the math, you'll quickly discover that for the dual 18" x 1.75" or more lift or dump cylinders on an FEL you'll: a) have a less lift capacity than with a higher pressure system, and b) it'll take a while to fully extend or retract. The single hydraulic cylinder on the 3, 4, and 500's is small and isn't being tasked with major loads so it can extend and retract quickly. Also small, on the 522, is the single power steering actuator cylinder. You'd also need to manage the extra fluid in the system (hoses, valves, cylinders) using a supplemental fluid reservoir. And lastly, the additional circuits would need their own pressure relief valve (these are built into WH valves used with Eatons) Lift time: 2 x pi x (1.75"/2) ^ 2 x 18 ÷ 231 ÷ 1.3 x 60 = 17 seconds 2 cylinders x area of the cylinder x length of cylinder ÷ 231 cubic inches per gallon ÷ GPM x 60 sec/min = time for full lift with load and no curl and no drive motion Max cylinder force: 2 x pi x (1.75"/2) ^ 2 x 725 = 2,562 lbs 2 cylinders x area of the cylinder x PSI = force exerted by the cylinders I don't know the weights or geometry of a loader so I can't convert this into usable load lifting but it'll be a lot less than 2,500 lbs. Edited March 13, 2022 by Handy Don 2 1 2 Share this post Link to post Share on other sites
Handy Don 15,933 #7 Posted March 13, 2022 Just found some load calculations for a basic loader and the working load limit was approximately 10% of the force available from the lift cylinders. It was running 2" cylinders and the pump gave 1,500 psi at 3 GPM so it's force was about 9,500 lbs and the working load limit was about 950. So for the calc's above for the Eaton, that's only 250 lbs in the bucket. Share this post Link to post Share on other sites
Pullstart 68,878 #8 Posted March 13, 2022 @Handy Don That’s what I was going to say! 1 5 Share this post Link to post Share on other sites
JoeM 9,617 #9 Posted March 13, 2022 6 gpm at 1000 psi using (2) 2 inch cylinders is just about the right configuration for the loaders I have built. Speed and power. On the 520LXI, I used an 8 gpm gear pump and it worked good because I hardly ever run full RPM. About 2/3 engine speed most often, and being water cooled, it works out good. Of course when needed I can dial it up. The lower pressure keeps me out of trouble. 2 Share this post Link to post Share on other sites
squonk 45,500 #10 Posted March 13, 2022 5 gpm and if I remember 1 3/4" cylinders on my Power King build. Things also change depending on pulley sizes driving the pump 1 Share this post Link to post Share on other sites
Damien Walker 297 #11 Posted March 19, 2022 On 3/12/2022 at 8:53 PM, Bill D said: Batting ideas around in my head for a dream build. I know of two Ariens GT 20 tractors near me that I may be able to pick up cheap. Both have full hydro steering. Would an Eaton 1100 be able to power the steering system from one of those tractors and the lift? Transmission in the Ariens is a Sunstrand. I drove one of the Ariens and I love the effortless steering. In addition the M20 in the Ariens could be used on a Wheel Horse if you used an electric PTO clutch. Thoughts? Has anyone done a full hydraulic steering setup on a Wheel Horse? Thanks. Hi Bill, search for my thread on my 518H with power steering. The Eaton 1100 can certainly do this. Wheel Horse 500H Series Power Steering Conversion Good luck! Share this post Link to post Share on other sites
