csvt99 173 #1 Posted March 12, 2022 I have an 877 that has been sitting for 2-3 years. I'm planning to replace the motor this spring so the kids can run it. I believe it has the Sunstrand hydro in it. Do I need to replace the fluid after sitting that long? Thanks! Share this post Link to post Share on other sites
Ed Kennell 43,483 #2 Posted March 12, 2022 (edited) Sitting 2-3 years is not a problem, but when was the fluid changed? Make sure you know what is in there now. It may be ATF (pink) or motor oil (amber). Do not mix the two. Edited March 12, 2022 by Ed Kennell 3 Share this post Link to post Share on other sites
squonk 44,813 #3 Posted March 12, 2022 877 Should have ATF (Dexron Mercon) unless someone went through the trouble to change it. I would at least change the filter Napa 1410 Wix 51410 3 Share this post Link to post Share on other sites
csvt99 173 #4 Posted March 12, 2022 Ok thanks. It has ATF and I changed it about 8 years ago when I replaced the o rings 🙂. I used it weekly for about 2-4 years after that, and then just occasionally. Share this post Link to post Share on other sites
Digger 66 3,488 #5 Posted March 12, 2022 My stance is : Fluid(s) is / are cheaper than gears , bearings , teardowns . If there's any doubt about the age or condition , drain & replace . 3 Share this post Link to post Share on other sites
Ed Kennell 43,483 #6 Posted March 12, 2022 5 hours ago, csvt99 said: I'm planning to replace the motor Why, just curious? Share this post Link to post Share on other sites
csvt99 173 #7 Posted March 12, 2022 1 hour ago, Ed Kennell said: Why, just curious? It was smoking badly and sqounk has a rebuilt one. 3 Share this post Link to post Share on other sites
Ed Kennell 43,483 #8 Posted March 12, 2022 51 minutes ago, csvt99 said: was smoking badly Oh, a bug killer. 1 Share this post Link to post Share on other sites
