Fishroe 261 #1 Posted March 10, 2022 Looking at the kohler magnum manual it shows a 1 post solenoid. This tractor has a 2 post. I just bought it not running. Solenoid was not mounted just hanging by 1 cable. Are these 2 factory connectors for the solenoid. Just making sure. Looks like they are my 86 414-8 has a 1 post. The 89 has a regulated charging system. Different type starter on the 89. Also what is that tube by the fuel filter for. It’s stuck in a hole in the frame Share this post Link to post Share on other sites
pfrederi 21,176 #2 Posted March 11, 2022 All solenoids will have two big posts. Some have one small post some two. Hard to tell if you solenoid is original (guessing not.) One small terminal feed power to trigger the solenoid. the second one may be a ground or maybe a bypass of a ballast resister ((some older car types especially Fords), Look closely one small terminal should show a + the other may have no mark or an "I". No mark make sure it is grounded and "I" leave it unconnected.... 2 1 Share this post Link to post Share on other sites
Fishroe 261 #4 Posted March 11, 2022 I found an electrical diagram of the tractor in the dymistification dept. not real good at reading those but it looks like it’s supposed to be a 2 post. Not getting voltage from the ignition switch took it off and all the resistance checks were good. Switch actually looked fairly new. Jumped the solenoid to check starter. Turned engine over good. Only did it for a second or two. Time to start backtracking safety switches and wiring i don’t believe the throttle shaft even has a bushing in the top it’s so much slop. The little shock cylinder for the seat don’t work. This thing is a frickin nightmare thanks for the info fellas aint it pretty 😂 Share this post Link to post Share on other sites
roadapples 6,987 #5 Posted March 11, 2022 I'd put the OLD air filter back on and blow that down real good if you have a compressor... 1 Share this post Link to post Share on other sites
Fishroe 261 #6 Posted March 11, 2022 Absolutely first thing I wanted to do is get it where I can turn the motor over with the key switch then clean up a little and check for spark 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #7 Posted March 11, 2022 The plastic tube likely plugged into a nipple to drain a plastic battery tray under the battery. 3 Share this post Link to post Share on other sites
peter lena 10,076 #8 Posted March 11, 2022 @Fishroe ,part of the overall issue , that air filter backing plate , engine vent tube , often hangs up , super lube makes it fit easily, your engine governor shaft ends , need a penetrant soak to help them move. this thing is a frickin nightmare , can relate . wiring is your main problem . jumper wires , cracked connections , corrosion . been there a few times , wish you luck , pete Share this post Link to post Share on other sites
WHX?? 58,218 #9 Posted March 11, 2022 Looks to me a good can of degreaser and a go round with a pressure washer would be a start. Make things easier to work on fer sure. Share this post Link to post Share on other sites
squonk 48,156 #10 Posted March 11, 2022 No sense in lubin dirt! 1 Share this post Link to post Share on other sites
Fishroe 261 #11 Posted March 11, 2022 Update I’ve got the starter working with the key switch just had to spray the wire connectors with brakekleen and air pressure. It does have spark next thing after breakfast is push it out of garage and blow off and spray engine down with purple power. Have Yal had any luck freeing up a frozen choke cable. If not, for now I’ll unhook the rod and work it by hand. Will change fuel filter and clean gas tank. Fuel valve feels pretty good. I don’t know if it will run. Top of throttle shaft has 3 or 4 millimeters of front to back play. Needs a new gas cap. Of all things to work all the dummy lights work except the low oil one when you do the test😂😂. Volt meter is working now although reading a little low. Haven’t cleaned those connectors yet. Battery is brand new Motor has wrong plug in it. Champion rj19lm my other 414 uses the H 10 C i’ll check the specs later on this magnum can you buy just the bushing for the carburetor or do you have to buy the whole kit probably better off buying the whole kit anyway parts list Carburetor kit gas cap this cap has the float on it One axle seal that’s leaking pretty bad transmission oil looks a little rough on the dipstick might have to do the flush with kerosene on this one wonder if it’s one place I can get all of these parts do they still sell the shock cylinder for the seat that don’t work either Share this post Link to post Share on other sites
WHX?? 58,218 #12 Posted March 11, 2022 5 minutes ago, Fishroe said: wonder if it’s one place I can get all of these parts Probably not but gas cap can be had here... https://www.capsandgauges.com/main.sc and the seat shock might be this one but check the part No. https://www.capsandgauges.com/main.sc He will also have the seal but if the seal is leaking chance the outer bearing maybe suspect so check that. Share this post Link to post Share on other sites
Fishroe 261 #13 Posted March 11, 2022 I hope not on the bearing I don’t want to have to go in transmission 😞😞 Share this post Link to post Share on other sites
WHX?? 58,218 #14 Posted March 11, 2022 45 minutes ago, Fishroe said: I hope not on the bearing Share this post Link to post Share on other sites
Fishroe 261 #15 Posted March 11, 2022 Thanks Mr West for that info. VERY helpful 1 Share this post Link to post Share on other sites
tunahead72 2,662 #16 Posted March 12, 2022 21 hours ago, Fishroe said: ... i don’t believe the throttle shaft even has a bushing in the top it’s so much slop. The little shock cylinder for the seat don’t work ... 9 hours ago, Fishroe said: ... can you buy just the bushing for the carburetor or do you have to buy the whole kit probably better off buying the whole kit anyway ... do they still sell the shock cylinder for the seat that don’t work either ... The carb probably didn't come from the factory with a bushing. The wear/slop is probably in the bore at the top of the carb. If there's a counterbore there (probably), you can add two bronze bushings from Ace Hardware (Hillman #58087) to take up the slop, may help a lot. There's threads here on the forum that describe the process, you'll have to remove the throttle shaft completely, which means removing the two screws holding the throttle plate to the shaft. It's not hard, see if you can find some of these threads with a search, I'll take a look and post a link or two if nobody else comes up with something. What do you mean by "the whole kit"? And have you seen the Kohler carb reference manual, and the Kohler throttle & choke shaft repair kit bulletins? Very useful: Engine Kohler Carburetor reference #TP-2377-E.pdf - Kohler - RedSquare Wheel Horse Forum The seat shock can be replaced. The "correct" cylinder is pricey from Toro, but there are apparently some aftermarket cylinders that are much cheaper and work just fine. Again, there's threads that address that issue also, I'll try to find something for you tomorrow. By the way, your 414-8 and my '88 310-8 could be cousins, I'm looking at some of the same issues on mine. Breathe deep, and have some fun with it, that's what I keep telling myself. Share this post Link to post Share on other sites
Fishroe 261 #17 Posted March 13, 2022 Tunahead just now saw your post i have a walboro 47 053 64 will the Hillman washer work on walboro also the throttle shaft measurements, is that for kohler carburetors only on the top right of that page it says kohler carburetors. I’m confused I haven’t taken the carburetor off yet the fuel valve bushing supposed be here tomorrow. I’ll then see if the motor runs Also when I googled the walboro carb # I couldn’t find any info. Share this post Link to post Share on other sites
tunahead72 2,662 #18 Posted March 13, 2022 1 hour ago, Fishroe said: i have a walboro 47 053 64 That carb does show up in the carb reference manual I mentioned earlier. It's a 1" carb with a fixed main jet, and you should be able to find all the part numbers you need there. will the Hillman washer work on walboro It should... I did that same repair on the Walbro carb on my '86 310-8 last year, and it worked just fine. also the throttle shaft measurements, is that for kohler carburetors only on the top right of that page it says kohler carburetors. I’m confused Good question, but I don't know the answer to that. Anybody else?... Also when I googled the walboro carb # I couldn’t find any info. Umm, did you spell Walbro correctly? 1 Share this post Link to post Share on other sites
Fishroe 261 #19 Posted March 14, 2022 (edited) 1 hour ago, tunahead72 said: Ok I found the info in the reference manual I think the first time I looked at it I didn’t have but one brain cell working 😂😂😂 Edited March 14, 2022 by Fishroe 1 Share this post Link to post Share on other sites
