"Manic-Mechanic" 1,420 #1 Posted March 4, 2022 (edited) The Tag Location The Tag Model The Drive & Lift Assembly Bearings Flushed & Re-packed High Heat Grease The Belt Cover Modified Spindle Protrusion Ready For Finish Coat 4 The Lift Handle Sequence Right Side Left Side The Left Lift Assembly-Wheel Backside View Of Left Assembly Backside Right Assembly Lift & Right Side Assembly Final Paint Belt Cover Edited March 5, 2022 by "Manic-Mechanic" 2 1 Share this post Link to post Share on other sites
peter lena 9,598 #2 Posted March 4, 2022 @" MANIC - MECHANIC ", looks good , R/D decks are my favorite , have a 36 like yours , and 2, 42" decks . like their clean cutting without any grass rowing , with regular service , and deck underside drying and lubrication , you can have a rust free set up , pete 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,420 #3 Posted March 4, 2022 18 minutes ago, peter lena said: @" MANIC - MECHANIC ", looks good , R/D decks are my favorite , have a 36 like yours , and 2, 42" decks . like their clean cutting without any grass rowing , with regular service , and deck underside drying and lubrication , you can have a rust free set up , pete Yes, exactly! Going to oil them and let it soak. I showed the break down of the sections as I couldn't find any reference materials other than a parts break down from 5-0620. Pictures are always a plus before disassembly as well, especially on first time rebuild of this odd linkage! 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,420 #4 Posted March 7, 2022 Here's the rest of the deck together on top, blades go on after the "oil soak". Share this post Link to post Share on other sites
