dmoore 1,023 #1 Posted February 20, 2022 I have discovered a little more side to side play in my throttle shaft on my Walbro 12 HP Kohler than should be. This may be the cause of slightly irregular idle at times. At WOT it has no effect. Does Kohler make a bushing repair kit for this? Thanks! Share this post Link to post Share on other sites
oliver2-44 11,214 #2 Posted February 20, 2022 Kohler bushing 2515802-5 NLA, you can check Evilbay but I have not seen one there in a good while. What most of us use is a Hillman bronze bushing 58087 found in those gray drawers at your hardware store. It goes in the top recess that was originally for a felt seal. Sometimes I can stack 2 of them, sometimes only one. If it is a little tight on the shaft take a drill bit and with just your fingers turn the bit to ream it out. 3 1 Share this post Link to post Share on other sites
dmoore 1,023 #3 Posted February 20, 2022 Thanks for that info. Now if I can only removed those two butterfly screws! Share this post Link to post Share on other sites
dmoore 1,023 #4 Posted February 20, 2022 I am wondering if that carb is still available? I bought this one new in 97 from where I can't remember right now. Share this post Link to post Share on other sites
Achto 31,015 #5 Posted February 20, 2022 37 minutes ago, dmoore said: I am wondering if that carb is still available? Just under 2 bills at this site. Kohler part #4785323S for a K301 http://www.psep.biz/store/kohler_carburetor_complete.htm Share this post Link to post Share on other sites
roadapples 6,987 #6 Posted February 20, 2022 File the tips of those screws off flush before trying to remove them. There usually brass and file very easy with a fine file... 1 1 Share this post Link to post Share on other sites
ranger 1,840 #7 Posted February 20, 2022 10 hours ago, roadapples said: File the tips of those screws off flush before trying to remove them. There usually brass and file very easy with a fine file... One little tip, (just about on topic), if you file brass, it’s best to use a new file, and keep it solely for use on brass. Once a file has been used on steel, it’s performance on brass is reduced considerably! Share this post Link to post Share on other sites
dmoore 1,023 #8 Posted February 20, 2022 (edited) Well I was 50% successful...ha! Edited February 20, 2022 by dmoore Share this post Link to post Share on other sites
dmoore 1,023 #9 Posted February 20, 2022 (edited) As for the play there is a bushing already installed. I guess it's factory? I can't remember installing one in this carb. So at this point I don't know if I have a worn shaft or bushing or both? Edited February 20, 2022 by dmoore Share this post Link to post Share on other sites
ranger 1,840 #10 Posted February 21, 2022 14 hours ago, dmoore said: Well I was 50% successful...ha! If the shaft itself is worn and you cant find another, clean it well where it’s worn and tin it with plumbers solder to build it back up, sand it, or machine it to size. You could also try ‘JB’ Weld, instead of solder. When you remove the remains of the sheared off screw, screw it ‘In’ to remove, rather than trying to screw it ‘Out’, it will probably be easier. 1 Share this post Link to post Share on other sites
dmoore 1,023 #11 Posted February 22, 2022 Ordered a new throttle shaft today. 1 Share this post Link to post Share on other sites
dmoore 1,023 #12 Posted February 24, 2022 (edited) My guy here ordered a new throttle shaft but it came in wrong. Way to short and the top portion was incorrect. Anyone have any luck finding the correct piece? Spec # 46766 Edited February 24, 2022 by dmoore Share this post Link to post Share on other sites
dmoore 1,023 #13 Posted February 25, 2022 So after searching for the correct throttle shaft and finding nothing I decided to buy this complete carb. It is supposed to be a direct replacement for my 470 53 13. What scares me is the price of $25.00 shipped. Coming from https://www.ebay.com/usr/partman-small-engine-parts?_trksid=p2047675.m3561.l2559 anyone else buy these? Thanks! Dave Share this post Link to post Share on other sites
pfrederi 19,887 #14 Posted February 25, 2022 (edited) Some have had luck with China carbs...some no luck. You pays your money you takes you r chance. at least the choke looks correct Edited February 25, 2022 by pfrederi 1 Share this post Link to post Share on other sites
ranger 1,840 #15 Posted February 25, 2022 If the Chinese carb doesn’t work well, you could maybe take the throttle spindle out of it and use it in the original carb? You never know, it might fit! 2 Share this post Link to post Share on other sites
dmoore 1,023 #16 Posted March 1, 2022 On 2/19/2022 at 9:25 PM, Achto said: Just under 2 bills at this site. Kohler part #4785323S for a K301 http://www.psep.biz/store/kohler_carburetor_complete.htm NLA No longer available 1 Share this post Link to post Share on other sites
