Dashunde 6 #1 Posted February 16, 2022 Hi All, I'm getting ready to dive into the inop governor on my (Grandpa's) 1965 1075's Kohler K241, the shaft will rotate all the way around, and I'm wondering how far I really need to disassemble it to get to the governor shaft? Other than the governor issue it runs pretty good, always starts, makes good power (more than it should I think), and doesn't leak, blow any blue smoke or seem to burn much oil, so I'd really like to just inspect the cylinder wall, knock the carbon off the piston/valves/head, pull the cam and install the shaft... is that doable or do I have to pull the crank entirely out to swap the governor shaft and gear? 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #2 Posted February 16, 2022 If you can turn that shaft all the way around, the flag is gone. Sorry, but you need to do a complete tear down to fix that...if that is what is going on. Pretty much, everything needs to come out to get to that shaft. There is a point of tear down that let's you see what is going on, but to fix it, it is the first thing that happens to re-build a block. 4 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #3 Posted February 16, 2022 41 minutes ago, stevasaurus said: If you can turn that shaft all the way around, the flag is gone. Sorry, but you need to do a complete tear down to fix that...if that is what is going on. Pretty much, everything needs to come out to get to that shaft. There is a point of tear down that let's you see what is going on, but to fix it, it is the first thing that happens to re-build a block. Steve said it. 'nuff said. Don Share this post Link to post Share on other sites
squonk 45,526 #4 Posted February 16, 2022 Seems to be an epidemic of broken governor shat flags lately. 1 Share this post Link to post Share on other sites
WHX?? 55,001 #5 Posted February 16, 2022 Yep... when you read the manual the guv is the last thing to come out and the first to go back in. Just about to button one back up once and put the oil pan on .... @Achto why did you leave that part in the parts cleaner?!?! 1 Share this post Link to post Share on other sites
RED-Z06 2,716 #6 Posted February 17, 2022 Pull head, pull shrouds, pull flywheel, lift engine off the pan onto a bench. Remove the starter, bearing plate, rod bolts, push the piston out, push the crank out. May be able to get at it...not sure on a 241 if you have to punch the cam out. Look at the cam gear for any damage. Youll have to check crank endplay and shim it back on assembly..inspect the bore, piston, look for cracks in the skirt. Clean the pan out..find the flag part. Share this post Link to post Share on other sites
ri702bill 11,256 #7 Posted February 17, 2022 5 hours ago, RED-Z06 said: find the flag part. Yup, my very first thought. Second thought - inspect the rectangular flag and look for ANY evidence of chew marks or other indications it got caught up in the rotating parts on the way to the bottom. Any damage warrants a much closer inspection of all the rotating parts. Bill Share this post Link to post Share on other sites
RED-Z06 2,716 #8 Posted February 17, 2022 Also vital to look at the governor gear and flyweights, its the same level of teardown to access it except you definitely do have to knock out the cam Share this post Link to post Share on other sites
stevasaurus 23,617 #9 Posted February 17, 2022 I think the broken flag pandemic is about a lot of members thinking their governor is not working right and when they go to adjust it, they don't realize you only turn the shaft until it stops and it doesn't take much (if any) pressure to hit the flag on the side of the block. It's only spot welded and fragile. Share this post Link to post Share on other sites
WHX?? 55,001 #10 Posted February 17, 2022 Agreed Steve... some of the ones I have had out were just riveted or staked and loose on so I brazed them on. There can be some force on them you get her on the gov in tall grass or heavy snow and workin. 1 Share this post Link to post Share on other sites
RED-Z06 2,716 #11 Posted February 17, 2022 20 minutes ago, stevasaurus said: I think the broken flag pandemic is about a lot of members thinking their governor is not working right and when they go to adjust it, they don't realize you only turn the shaft until it stops and it doesn't take much (if any) pressure to hit the flag on the side of the block. It's only spot welded and fragile. I had one break because my sleeve snagged the governor arm and tweaked it..they aren't the best made for such a critical hard to replace part 1 Share this post Link to post Share on other sites
